Question about Panasonic Televison & Video
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
Message on tv keeps popping up...air filter needs cleaning please call for service tv will shut off in one minute.Tv shuts off after a minute
  • 1 more comment
  • MuzakMan Jun 14, 2008
    Having the same problem.... can't find the filter...
  • Anonymous Dec 01, 2008
    cleaning air filter on panasonic hdtv
  • monteseyes4r Dec 11, 2008
    Same message and problem for Air filter needs cleaning please call for service tv will shut off in one minute. So i did try Q tips on the filters.(located behind panels in the front of tv) One is easy to see and the other one below it looks like its suspended. Pluged it up,and waited 2 hrs then turned it on. It lasted about 8hrs. Then the message appeared again! Can they be cleaned different?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Oct 18, 2009
I would like to clean air filter myself....Is this hard to do???
Posted on Feb 23, 2010
A message keeps popping up saying I need to clean the air filter then the tv shuts off on it's own. It's a panasonic 60 inch projection
there is a louvered air intake panel on either lower side of tv. there is 1 or 2 screws the filter is right behind that panel.. take it out and clean it with warm dishsoapy water and pat dry on a flat surface with paper towels then reinstall. your th will not come on till the panel is screwed back into place. there is a microswitch type sensor that makes sure that the screws are in place...goodday
Nov 13, 2009 | Panasonic PT-60LCX64 Television
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Air filter keep popping on screen and shut off after 1 minute.
I had the same problem with my Panasonic tv, just 3 days after a technician came out to fix "fuzzy spots" which were multi colored, but mostly green spots. I really thought that the technician was in some way responsible, but Panasonic insisted that there was no possible way he was. It was going to cost $240.00 for him to come out to clean the air filter, and both the technician and Panasonic insisted that I couldn't do it myself. I had decided to buy a new tv to cut my losses. My boyfriend talked me into trying to fix it, we are both sort of mechanically inclined, and it was going in the trash anyway.
We took the back and top off the tv. It took some looking, but we finally found the filter, just over the projector. We removed the cover, it has to be done from the back of the tv, it is black and held on by 4 small screws, be careful not to drop them into the tv, we dropped one, but it shook out. We vacuumed the filter really well, and vacuumed around everywhere. We put the tv back together, not expecting it to work, but thinking at least we tried. It works great. It has only been a few days, but it seems like the problem has been solved.
Good luck if you decide to try. I have decided not to put another penny into the tv.
Jan 07, 2009 | Panasonic PT-60LCX64 Television
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air Filter Cleaning
Call the factory for an authorized servicer near you, your TV guy doesn't understand Panasonic...
If the lamp thermal sensor is active, the fans just keep running because it thinks the thing is hot (to save an expensive part from exploding). It does not give any error message.
Fan 1 is used for air filter detection. (It's essentially the same run-sensor type fan used in their stereos.) Fan 1 plug P2902 at the right side of the light engine board may not be making good contact or the fan is not running. The micro must get the proper feedback signal from that fan to keep it happy.
Good luck, Mark
Jul 23, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Jun 11, 2008 | Panasonic PT-52LCX66 Projection Television
Air fitler cleaning
REMOVE THE BOTTOM PANEL OF THE BACK OF THE TV. CLEAN OUT PANEL WITH WATER AND DRY.(IF NOT DRYED OUT PROPERLY CAN CAUSE SHORT) CLEAN OF THE FAN ON THE BACK RIGHT SIDE (REMOVE ALL DUST) THEN REINSTALL BACK PANEL. TV SHOULD WORK
Nov 07, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
1,150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
