Question about SanDisk Sansa Clip MP3 Player
Stuck on Refreshing Database
I plugged my MP3 player into a computer to get some songs, then i unhooked it and it's stuck on "Refreshing Database." No matter how long i wait it won't stop refreshing.
  • 8,596 Answers
It needs a firmware upgrade, most likely. Read the following for every possible recovery method:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
It freezes when it says refreshing database.i erased all the songs because out of nowhere it said most of my songs were bad tracks so i erased all of them then when i turned it on it says refreshing...
your mp3 player's software got corrupted...please go to your nearest SanDisk customer care....if warranty period of the mp3 player is still there....they ll reinstall the software for free...other wise they charge u some minimum cost....
Apr 05, 2010 | SanDisk Sansa e250 MP3 Player
The sansa clip got stuck on
try contacting sandisk or something and ask them
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Stuck on fresh database
Some songs or files with extension device can't read, so it takes so long/infinity to refresh. Plug the device to pc, format it.
Good luck
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
The screen is stuck on a screensaver and it will not turn off or do anything
It often happens when it doesn't a file is corrupted. If it gets stuck on "Refreshing database", turn it off by holding the power switch until it shuts down, then plug it on a computer and when the sansa logo appears, unplug it. It will skip the datebase refresh and you'll be able to reformat it.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
Database not refreshing, Could not listen the new songs added
go into your menu go into veiw all songs then go to play all
May 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e260 - Stuck on "Refresh Database" after uploading music
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
Apr 19, 2008 | SanDisk Sansa e260 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Refreshing Database
I love you!! thanks this helped me :)
Jan 28, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
220 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
