I dropped my camera yesterday and the lcd monitor was damaged, is there anything I can do I love my camera and im leaving for college in july and at this moment can not afford to buy another one, are there any way to repair it?
If the LCD was physically cracked or broken, then yes you should be able to swap it for an undamaged one.
The cheapest option for you is to advertise or look on Ebay for an identical model - also with faults, but with an undamaged display. (maybe dropped - sold as not working)
See HERE - this is just like yours - but also has the cracked LCD. You need to search for one with a good display.
Take this "donor" apart first to see how it's assembled, then just swap the parts.
This method of repair is common for consumer electronics.
Thanks for using Fixya!. If this has provided a solution, plrease rate as such. Thanks.
Konica Minolta Dimage x50 digital camera won't take still pictures. Red light flashes when in still...
(More)
Konica Minolta Dimage x50 digital camera won't take still pictures. Red light flashes when in still mode. Video function works well. Help!
We are having an issue with our Konica Minolta Dimage E500. It turns on but the lens does not seem...
(More)
We are having an issue with our Konica Minolta Dimage E500. It turns on but the lens does not seem to show anything but black. All the LCD functions are displayed and the memory card works. Please advise.
I have the same problem too. The cam havn´t been dropped or mistreated in any way, still...
(More)
I have the same problem too. The cam havn´t been dropped or mistreated in any way, still one day when trying to use it the display was white. I've acctually opened it in a deperate attempt to find any broken or loose connections, din't find any. I did however find the internal battery, could it be so that this is the symptom of a runned out internal battery that needs to be replaced? I've had my cam for more then 4 years and I've used it quite frequently.
