15 inch CRT monitor - NCR ATM
Mains filter 68uf/400v is getting burst after 5 seconds when the monitor is powered ON.
Hout- BUH1015H removed , 4 Diodes ( Bridge Rectifier ) , 1N5399 changed new, Cap 68uf/450 V changed new and tested still same condition i.e. Filter CAp getting burst, Please help me in solving this problem.
Thanx & regards,
K.Kothandaraman
Crt monitor picture size very small height no increasing small in size tell any ideas
Posted on Oct 17, 2012
Power on problem
sounds like your monitor has bad capacitors. When a monitor begins to overheat the capacitors may begin to burst or leak which will not do its job to hold electrical current sufficiently and cause the display to become blank.
Mar 28, 2014 | SAMTRON 55V 15" CRT Monitor
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
The problem is power out put voltage diodes are completely burned I not getting the value of the diodes The voltages are 72v 50v 6.3v 13v -12v These are out put voltages .so please sending me...
hi;
  1. Diode: UF4007, 1000V 1Ampere ; for 72V
  2. Diode: GUR460L, 600V, 4Ampere : for 50V
  3. Diode: UF5404,400V, 3Ampere: for 6.3V
  4. Diode: UF1G, 400V, 1.2Ampere: for 13V
  5. Diode: TVR10G, 400V, 1Ampere: for -12V
Nov 12, 2010 | SAMTRON 55V 15" CRT Monitor
Hello sir, i hav LG CRT 15" monitor. After turning on, its LED continuous blinks and power button does not work and displays nothing. so plz suggest me what should be deffect?
Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
Oct 04, 2010 | Computers & Internet
RCA VHS/DVD recorder/player Model DRC832ON does not power up. It is plugged in to the home AC receptacle and was working fine, then for no apparent reason would no longer turn on.
Replace the C232 capacitor on the power supply board. It is about an inch high and black/blue with a silver top.
This solution was also posted on Dec. 4.
Dec 06, 2009 | RCA DRC8300N DVD Recorder/VCR
After Monitor is ON, A Sound like chi chi coming out.
yes you first check the capacitor in primary filter 150microfarad/400v if faulty then replace it if not then check boost capacitor near eht (big capacitor near yoke connecter)if faulty replace it
Nov 17, 2008 | SAMTRON 55V 15" CRT Monitor
LG Studioworks 552V hout burns off
1. cheak the G2 , G4 wires. ( properly fixed it )
2. Near to LOT one flyback capacitor 1600 / 2KV problem.
3. damper diode BYW 96
4. LOT Problem.
Oct 24, 2008 | LG Studioworks 552V 15" CRT Monitor
15" CRT Monitor samsung totally dead
Dear munu007 good morning this is viswanath
Don't worry I can salove UR problem
1.First U can check any physical damage in power supply (220/400v)Main capacitor,
2.And also check LOT It's OK Than Remove H O/p Transister, check SMPS output voltages ,voltages are currect That means SMPS is OK.Check Boosting FET IRF630(Q402)Change it New One,and also change the IC604 7805 Regulator.
Finally change LOT.
check any dry points (SMPS&Hori.)
Oct 08, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Sep 14, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Computers & Internet Logo
434 people viewed this question
David Payne
David Payne
