Question about RCA L26W11 26 in. HD-Ready LCD Television
TV Screen not functioning correct
After turniong the set on for approximately 10 minutes, the screen will turn solid white and the backgriund sound is still playing. Just do not have picture. Do I have a setting that needs to be disabled?
  • 42 Answers
Sounds more like a malfunction. Most likely the lcd panel or digital board. If lucky possible a bad solder connection but unlikely.
Posted on Jul 06, 2008
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
My tv projector, the screen turn black no picture and for awhile just sound and than turns off, after 5 or 10 minutes, how can i fix the problem with out call a technician
Unfortunately in this scenario the only way you can fix your TV is by calling a technician. It sounds like your power board is failing and you will need to replace that in order for it to function correctly again.
Mar 03, 2011 | Pioneer Televison & Video
Memorex mlt3221. white screen, no sound, no function.
Check the power supply module for bad DC filter caps first, then check the backlight inverter board for shorts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Jul 29, 2010 | Memorex MLT3221 32 in. LCD TV
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Picture disappears and changes to white screen
I am assuming that this is the nature of the fault and that it is repeatable. Does what you have described occurs every time you turn the damn thing on. You haven't said is whether or not there are changes in sound when the screen malfunctions or whether your unit plugs into a GPO or a black box which plugs into the GPO.However this only dictates the ease with which the faulty component is replaced What seems to be happening is that white level controls are setting to maximum gain. If the control is digital It is almost certainly due to dirty power. The sound level should also change if the power supply is the culprit. Spikes cause the gain on the control to ramp up or down erratically (change) on digital parameter controls. This resulting in bleeding for white levels and a change in the sound levels. Replace the power supply if possible. A cheap workaround can be made if my assumptions are correct and the main transformer is not faulty. Leave a post if you want more info
Aug 01, 2007 | TruTech PLV1615T 15 in. LCD Television
RCA L26W11 26 in. HD-Ready LCD Television Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
