Question about Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC
My computer will not go to stand by or sleep mode
When I press sleep button on my keyboard it used to go to stand by or sleep mode. But now, blue screen appears and it says "Preparing for stand by" and nothing happens. I can't get rid of the blue screen unless I manually shut down my computer. Please help...
Running windows XP.
Thanks
  • 30 Answers
Were you able to make the computer go to sleep mode before? Well what you can try doing is go to start, run and type msconfig, click ok. You will get the system configuration window, then go to the startup tab in the system configuration window and at the bottom of the window there is a button as disable all, click that and on the same window there are startup items, select the antivirus program and items that you would need to have at the task bar. Then click apply and ok. You will get a message to restart the computer. Click restart. As it restarts you will get a message saying that you have used the system configuration window, click do not show me the message again in the message. Also you can go to start, right click on My computer and go to properties, click the hardware tab, and select the device manager button. That would show you the device manager window. From the list of hardwares listed in the window, right click on network adaptors, properties and under the power management tab uncheck all the power options checkboxes. Now you can close all the windows and try to go to sleep mode again. You can also try disconnecting the USB devices as you try going to sleep mode and see if that works, if yes, try connecting the USB devices one at a time and check again.
Posted on Jun 05, 2008
Computer will not wake up from sleep mode
Best way to restart it from wake up is remove the battery (if it is a laptop) or push the power button for at least 10 seconds (or more) until you can't see any lights at all or any sound from the hard drive. That is the only way you can restart the computer if it is not waking up from sleep mode.
Dec 14, 2017 | Computers & Internet
Flashing power button
If the power button is flashing or blinking, that means the system has entered sleep mode, low power state. I would suggest not meddling anything related to power, sleep mode was designed for reducing power consumption if the machine was not in use for a set amount of time. It also helps you reduce your electric bill.
If you want to use the machine if it is in sleep mode, just simply press the power button on the computer or by pressing the keyboard or mouse to get it out of sleep. Think of sleep mode as a 2 hour power nap.
Jan 19, 2014 | HP Pavilion Desktop a6300f Intel Pentium...
Pleomax keyboard pkb 700b shortcut does not work
look below the enter key one turbo key also available
if you want to use three of these buttons like power off,sleep,etc
press turbo key and then press one of these its really working and very quite
Amrit
Jun 13, 2012 | Samsung Pleomax PKB-700B Keyboard
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
I put my laptop in the sleep mode as a requirement for using "Magic Jack" and have using the power switch to go out of sleep mode and activate Vista. I read this could cause problems later but don't know...
On most computers, you can resume working by pressing your computer's power button. However, not all computers are the same. You might be able to wake your computer by pressing any key on the keyboard, clicking a mouse button, or opening the lid on a laptop.
It just need an interruption to wake from the sleep mode so its perfectly ok to do so by any key or by the power key....
For any further guidelines give a comment...
Feb 28, 2010 | Computers & Internet
There are several keys on my keyboard that do not work i.e. Power, Sleep, Wake buttons.
Your computer needs a fully function chipset driver for it to work. You can install the driver from the support disc of the motherboard. This features stand by mode, sleep/wake and power on using your keyboard. You should configure also your computer bios. Go to Power Management section of the BIOS.
Dec 23, 2009 | Micro Innovations Advanta Keyboard
Curious - What is the moon shaped key all about
this button puts the computer into sleep mode.
FROM WIKIPEDIA-
Sleep mode can go by many different names, including Stand By (Microsoft Windows 95-Server 2003), Sleep (Mac OS 8)-(Mac OS X) / (Windows Vista,Windows Server 2008), and Suspend (Linux). When placed in this Sleep mode, aside from the RAM which is required to restore the machine's state, the computer attempts to cut power to all unneeded parts of the machine. Because of the large power savings, most laptops automatically enter this mode when the computer is running on batteries and the lid is closed.
Though Sleep and Hibernate are generally thought as two separate functions, modern Macintoshes, Windows Vista (termed Hybrid Sleep), and some specially configured Linux machines also feature a variation of Sleep mode that incorporates the strengths of Hibernate. The RAM is copied to the hard drive before sleep mode is initiated, preserving the RAM contents in the event of a power loss.
ACPI is the current standard for power management, superseding APM and providing the backbone for sleep and hibernation on modern computers. Sleep mode corresponds to ACPI mode S3. When a non-ACPI device is plugged in, Windows will sometimes disable stand-by functionality for the whole operating system. Without ACPI functionality, as seen on older hardware, sleep mode is usually restricted to turning off the monitor and spinning down the hard drive.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 04, 2009 | HP Computers & Internet
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Sleep mode
usually, to get a PC out of sleep mode, you either press the ESC key, press the power button a bit quickly, or press the sleep key agian. It really depends on the system. Try any of those to see if it helps.
-Chad
Dec 12, 2007 | Compaq Keyboard
Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC Logo
112 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
