Question about HP PSC 2175 All-In-One InkJet Printer
I don't remember the trick for closing it when changing cartridge
I need to do it right now so my kid can get his paper done and graduate but it's been so long I forgot how to make the thing drop down again!
  • HP Master
  • 13,433 Answers
Is it normal or common for kids graduating from high school to not go straight to college/university?
Yes, it definitely common in this day and age. A lot of kids graduating from high school will take a gap year and start university/college in the following year or some time off to do some travelling.
Jan 04, 2017 | Higher Education (University)
I can't install my cartridge in my Deskjet 3512.
Turn the printer on.
Load paper into the paper input tray.
Open the cartridge door (located on the front of the printer), look for the recessed area, grab the built in handle (part of the recessed area) and pull forward.
Once the door is open, the cartridges will automatically move to the center position.
To change a cartridge, pull the top, front of the cartridge down, it will move to a 45 deg position. Then just pull out.
Open the new cartridge box, take the cartridge out of the wrapper, pull the tab to remove the tape covering the electrical contacts, (make certain you don't touch the contacts or ink nozzles), install the new cartridge (color on left, black on right), slide it into the holder and press up on the top, back until it latches into place. Then close the door.
The printer will print a test page. Once printed, take the alignment page it printed and put on the scanner glass (corner to top, right, see the guide printed there). Close the scanner lid and press the OK on the control panel. the printer will now align the print heads based on the page it printed. Once done, press OK again. Done.
Oct 20, 2014 | HP Office Equipment & Supplies
Printhead cartridge jams
Hello, sorry took so long but, seems to be a paper jam or loose ink cartridge, open lid with unit unplugged and try and see any paper jammed in rollers or pieces of paper, then with that done and hopefully fixed but if not, close lid and turn unit on then open lid to access print cartridges make sure they are installed right and the right ones in the right slots if the cartridge unit don't move so as to load cartridges in try to gently pull it to position as a cartridge may have not been locked in or jarred loose.good luck hope this is of some help.
Dec 09, 2011 | Kodak   ESP5250 Es Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
How to refill the ink?
There is no ink......the Thermal paper is sensitive to heat and turns black when it is heated.
If you use thermal paper the printer heats the paper to create your printed message. Some of these papers are side sensitive so be sure to feed it in right side up!
Sep 22, 2010 | Dymo LetraTAG Thermal Label Printer
Green light flashing wont print
Many possible issues:
1) the cover is open (close cover)
2) Out of paper (add paper)
3) printer can't pick up media (change media, change printer print mode setting or paper type selection)
4) Paper jam (remove all media from the paper trays, press the power button once, remove the back cover and pull the jammed paper from that point then close the cover, reload the paper and try to print)
5) Problem with the cartridge (remove the cartridges and then reinsert them, try a cleaning cycle. Alternatively manually clean the cartridges (remove them from the printer and power down and unplug the unit). Use distilled or bottled water and cotton swabs. Slightly moisten the swab and wipe the face, edges of the cartridges - do not touch the contacts or nozzles. Wipe down the underside of the print cartridge cradle walls. Reinsert the cartridges, close the cover and power up the unit. Calibrate the cartridges. If this doesn't help, replace the cartridges.)
6) Loss of electrical contact between the carriage connections (press and hold the power button and open and close the top cover 4 times. Look at the resulting self-test print out. Remove and reinsert the cartridges and try to print. Next clean the cartridges and cartridge cradle as above. Replace the cartridges.)
I hope one of these solutions work. Otherwise the printer needs service.
Aug 05, 2010 | HP DeskJet 3650 InkJet Printer
It prints in color,but not in black whith a new cartrige.i tryed whith the old one,same result.
I had the same issue and resolved it this way:
- go to Start/Printers and Faxes
- right click the printer
- select Printing Preferences
- choose Inkjet Paper as the Media Type
Mine was set to Plain Paper. I'm not sure if it "magically" changed when I changed the cartridges but setting it to Inkjet Paper did the trick.
I did this after replacing all the cartridges and reinstalling the printer. Try this first and save yourself the money of the cartridges and the hassle of reinstalling.
Jul 11, 2009 | Brother MFC-465CN InkJet Printer
Printer changing color of paper
Make sure the transfer belt is clean. Also check the magenta cartridge and see if it isn't leaking slightly. By all means DON"T blow it out with compressed air! You may use a toner vacuum or a soft cloth to clean out any residual toner. If that doesn't do the trick, you may have a contaminated fuser. By the way, do you get the same effect when printing black and white?
Apr 20, 2009 | HP Color LaserJet 2600n Printer
PAPER JAM
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  1. Turn off the all-in-one and unplug the power cord.
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
