Question about Ricoh Aficio CL7200D Laser Printer
Ricoh CL7200D Replace Fusing Unit (type C)
Our Ricoh displayed a msg to replace the Fusing Unit (Type C) soon. We order and received the new part but waited until the msg to replace appeared. After replacing it this morning, the msg is still showing along with the solid "Red Alert" light indicator. What is the next step?
Please reply to Dee at dee.schmidt@mccst.com
Thanks much!
  • Anonymous Aug 08, 2008
    Same exact issue.
  • Anonymous Feb 03, 2009
    I have Aficio CL7300 and i cant enter in service mode menu.
    Thanks
Press the two arrow for 10 sec. hit enter you are in service mode
go to engine and diagnostic1 and sp7804 and go to 16
reset fuser change. enter
Posted on Dec 11, 2008
  • Marc Herman
    Marc Herman Sep 07, 2012
    what do you mean with "two arrow"; I don't see that on my dashboard
Ricoh 430dn error sc565
Pressure roller fusing lamp consecutive full power 3
When the fusing unit is not running in the ready condition, the pressure
roller fusing lamp keeps ON full power for 30 seconds or more.
?? Broken pressure roller thermostat
?? Broken pressure roller fusing lamp
1. Replace the pressure roller fusing lamp.
2. Replace the pressure roller thermostat.
3. Replace the PSU.
May 19, 2014 | Ricoh SP C430DN Laser Printer
How to reset a replace fusing belt unit error msg for ricoh mp c3502
Hi.
It needs to be replace the Fusing Belt or na expecifique Fuse (if the belt is still ok). Enyway you need to have knowledge and tecnical skils for do it. It is not a simple procedure ever for a high skill tec
Dec 28, 2013 | Ricoh Aficio CL3500N Laser Printer
Displaying functional problem SC542
press the yellow [c]-(clear) button then type 1-0-7 in order and then press and hold down pressed the red button [c]-(stop) until on the screen change after the screen will change do not touch nothing on the touch panel just turn off the machine by the main switch and turn it on again after 5 second if the problem still is here the machine need to be checked by a trained Ricoh technician
Mar 03, 2011 | Ricoh Aficio 2022 Black and White Copier
My Ricoh 388 is in need of replacing the fuser unit which we just replaced months ago and are very expenseive. Is there a way to fill the oil only in the fuser unit instead of having to replace the entire...
Unfortunately, on the AP3800C the oil supply unit is part of the fusing unit. However, you can purchase just the oil supply portion of the fusing unit and replace that (part #G0604022).
I'm not sure how much that would cost, but it's got to be cheaper than a whole new fusing unit.
Jul 11, 2010 | Ricoh Aficio AP3800C Laser Printer
Replace fusing unit error
Can you put the old fuser back, just to see if the message clears.
Mar 04, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Nov 17, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
Ricoh Aficio CL7200D Laser Printer Logo
1,241 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
