Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sportwon't respond after power outage
This washer is only 3 months old, I've never had a problem. My power went out yesterday, and now, the screen is blinking a 1 (?)-Just a vertical line on the right side. There is no F. It won't respond to anything. I didn't have a power surge. Can anyone help?
    Problem Solver:
You can try to reset the unit by unpluging it for about 30mins. i have a problem with my washer now and this is one trick they told me to try...hope this will help. good luck.
Posted on Oct 11, 2008
  • brock why u want to know...lol
    the "they" i speek of is whirlpool, sorry for not explaining this.
  • 19 Answers
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Posted on Jun 06, 2008
Due to power outage can't get door open on Whirlpool Duet front loader washer. With wet towels inside, need to manually open door to get them out. Is there an easy solution?
On that type of washer the door lock is wired in series with the water level switch and if water remains in tub the door lock will not power up and unlock..what you can try is (if havent already done so) is select the drain/spin only cycle and when the water has drained the door should unlock
Aug 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet washing machine. We had a
Unplug the machine.
Remove the lower front panel.
Reach your arm up inside on the door latch side. Feel for a pull ring and pull it to release the door.
Feb 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
No Power at Control Panel
sounds like a fuse issue. check the fuses.
May 24, 2009 | Whirlpool GHW9400 Duet Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
468 people viewed this question
Dan Webster
Dan Webster
Sal De
