Question about Amana Dryers
Amana heavy duty clothes dryer, model LE8407W2 screeching loudly when running for first several minutes....then stops.
  • 868 Answers
Belt idler pulley sounds dry, oil all rollers and belt pulley.Please leave a Rating! Thanx!
Posted on Jun 05, 2008
Model 69822 is less than 8 years old. Screeches loudly for about a minute on startup. Runs fine after that and dries the clothes.
The screeching is probably a slipping belt. This can be caused by"
1. Glazed or worn out belt.
2. Improper belt tension.
3. Overloaded dryer
4. Bad drum bearing
If it is used heavily (often), I would assume #1 which is the cheapest and quickest fix. You can investigate #2 at the time of replacement.
Jan 26, 2016 | Kenmore Dryers
My Amana distinction started making a loud sound like maybe the belt and I have to take cloths out of it. Now it stopped altogether. Is it the belt or drum?
Amana Dryer Makes Noise - Model DLE330RAW - Repair ...
www.repairclinic.com/...-/Amana-Dryer-makes-noise-DLE330RAW
When the drum rollers are worn out, they can cause the dryer to make a loud rumblingnoise. To determine if the rollers are worn out, inspect the rollers. If one or ...
Nov 26, 2015 | Amana Dryers
My Amana Electric Dryer Randomly stops working and it won't start up again , it can take up to an hour for it to work again. Model Number LE8407W2.
There are safety sensors that will break the current when it gets too hot or if the sensors themselves are failing. This will shut the dryer off or make it quit heating. After cooling down or at random times the sensor may make connection again allowing the dryer to work. These can only be checked out using an OHM meter and must be checked when they are not allowing the dryer to run.
Jan 22, 2013 | Amana Dryers
AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
I have the heavy duty 4 cycle Amana dryer. When I turn it on it is very loud and stops after about 20 minutes. It smells really hot so maybe it's overheating? But why?
sounds like motor bearings are failing. causes motor to overheat and cut out on motor protector. I'm afraid a new motor is in order.
Jun 15, 2010 | Amana DLE330RAW Electric Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Dryers Logo
535 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
