Question about GE 27GT616 27" TV
Blown TV fuse
I have a blown TV fuse but I'm not sure how to read the symbols on it or the type of fuse. It is white with metal ends and on one of the ends are the words and numbers: T4AH250V (with 3 circles after it). On the other end is a series of symbols with 50CT and the 3 circles again.
What do I need to ask for at the electronics store?
  • steve o rido Jun 15, 2008
    I got exactly the same problem. Would like to know what to order !
    President:
  • 1,284 Answers
It is a T type fuse rated at 4 amps.
Posted on Jul 19, 2008
What does a blown fuse look like in a lg tv 60in
glass fuse --no wire in the glass section
test with a multi meter set on ohms when leads are placed on either end of the fuse ( removed from the holder) there should be continuity ( no ohms reading) if it is blown the high ohms reading will not alter
Oct 25, 2016 | LG Televison & Video
Tip
Usually this is due to a thermal fuse being blown. To check for a blown thermal...
If the electric dryer does not work at all then there are some possibilities that have to be checked to confirm the fault.
1) Check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not working is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) One more reason for dryer not working at all is the fault in the door switch. The dryer will not start working till the door is closed. But if the door switch or the door-switch actuator is got cracked or worn out or loose then door will not get closed properly and dryer will not work. In this case check the door switch/actuator and replace it if required.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get power and will not work.
This will help. Thanks.
on Apr 25, 2010 | Dryers
Fuse manual layout picture
The circuit that the fuse is on won't have power-nothing will come on or work on that circuit. You can pull the fuse out and see if the element inside has snapped apart, or the easiest way to check fuses is with a test light. On the top of all fuses, there are two small cavities or indents-one at each end of fuse top. These are test points or probes for fuses- the metal is exposed through the cavity. Ground a test light lead to a good metal bracket or bolt under the dash. Now turn key to ON-do not start engine. With key on every fuse on the car will be powered-every one. Touch your test light probe to one of the indents. If test light does not come on, it is not grounded well. Make sure you have it grounded good. Now use the probe to touch both ends of the fuse, first one end and then the other end. A good fuse will light tester on both ends of fuse-meaning the element inside has not blown. A bad or blown fuse will only light up the test light on one end of fuse. If fuse has blown, power will not pass through the fuse, but will be stopped at the fuse on the one side. Check your fuses this way and you will not have to pull the fuse out to inspect it. You can also check the fuses under the hood (all fuses, including the larger maxi-fuses).
Post back if you have any questions, or unsure of my description.
May 31, 2013 | 2005 Lincoln Navigator
How to test a fuse
Remove the fuse from the fuse holder.
Use a multi-meter aet to low ohms scale.
Place each probe on the ends of the fuse, if the multi-meter shows a low reading then the fuseis OK. If the multi-meter shows a high reading or no reading the the fuse is open circuit or blown.
If the fuse is a glass type and it is burnt on the inside then the fuse is blown.
Dec 09, 2011 | Vizio 42 in. LCD TV
No power
First Check the power cord to TV, try a different one.
If you are experienced you can take the back panel off the TV
Check for
- Internal fuse inside TV might have blown, its on the power supply board (white fuse, slow blow)
- Buldging Capacitors or they may have leaked brown substance on top or circuit board
If you are going to do this yourself make sure you do not touch the contacts on under side of the circuit board that connect to the LARGE capacitor (looks like a giant battery)
Replacing the fuse is easy no experience needed, make sure you replace it for an exact match, it will say the rating on the metal caps at each end of the fuse.
If it is not the fuse you can de solder the blown capacitors and replace them with new ones.
Total Cost of repair if you have soldering iron and tools will only be about £3 or $5
Otherwise get a pro to repair it for you, but you might pay around £80 or $120
OR
You can note down the model name on the power supply circuit board and Google it.
You might be able to buy a replacement power supply which will be cheaper than paying a TV repair man to get the part and fit it
Hope this helps
Apr 07, 2011 | Sharp Televison & Video
Have unplugged and moved the tv and now can't turn it on
You may have a blown fuse. First unplug the TV and take the back off of it and then look for a tube shaped glass with two metal ends. Take it out and visually inspect it, if it looks burnt on the inside then you have a blown fuse if it does not look burnt, take a multimeter set to resistance and measure the resistance between the two metal ends (put the leads of the meter on the metal ends, black on one and red on the other) you should read 0 ohms...any other reading is bad. Now if the fuse is bad buy replacement fuses from your local electronics parts store or from Radio Shack. Replace the fuse and see if this solves your problem. Plug the set back in and if the set powers up and remains up unplug the set again put the back on again and you are finished.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Televison & Video
INSIGNIA NS-30HTV TV will not power on after a/c power failure
It may just be a fuse that is blown. If you take the back cover off and follow the power cord you should be able to find the a.c line fuse, it will be a glass fuse with metal end caps.
A blown fuse will show a broken filament inside or blackened glass. You may also have d.c fuses inside , they will look the same sa the a.c fuse. Their values should be written on the circuit board near the fuses and always on one of the end cap.
something like250V/3A for 3 amps. Hope this will help. Good luck
Dec 02, 2009 | Insignia NS-30HTV 30" TV
No picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
May 29, 2009 | Vizio GV47LF Television
Blown fuse inside tv
Look at the fuse you pulled out. The rating is embossed on the side or end.
Dec 28, 2008 | Apex Digital AT2008 20" TV
TV not turning on
Hello swami nathan,
You may have a blown fuse. First unplug the TV and take the back off of it and then look for a tube shaped glass with two metal ends. Take it our and visually inspect it, if it looks burnt on the inside then you have a blown fuse if it does not look burnt, take a multimeter set to resistance and measure the resistance between the two metal ends (put the leads of the meter on the metal ends, black on one and red on the other) you should read 0 ohms (zero ohms) any other reading is bad. Now if the fuse is bad buy replacement fuses from your local electronics parts store or from Radio Shack. Replace the fuse and see if this solves your problem. Plug the set back in and if the set powers up and remains up unplug the set again put the back on again and you are finished.
If the fuse blows again you may have a problem in your LV power supply path or your HV power supply path. In either case this requires that you know electronics, and I would suggest that you take your TV to a qualified TV technician.
I hope this helps
Thank you,
Shuttle83
Oct 03, 2008 | Televison & Video
Televison & Video Logo
362 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
