Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Eureka Bagless Widetrack, The Boss, Vacume, model 5893
The motor will not shut off with the switch, it has to be un-pluged. I replaced the switch and it still does not shut off.
    Problem Solver:
  • 13 Answers
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
Posted on Jan 30, 2010
This **** sucks!
Posted on Aug 22, 2008
Return it. The vacuum is incorrectly wired.
Posted on Jul 27, 2008
I have the eureka boss 4495 widetrack and the end piece of the beater bar broke off. I guess I put it back together wrong when I put a new belt on. Where can I get a replacement part and will it work do...
Call the Eureka people (1-800-282-2886) and describe to them what the beater bar thingy that you broke is. Ask them if you can order that unit--if you think you can install it. Otherwise, ask them where to the authorized repair person closest to you is located. Price the repair versus a new vacuum and good luck.
Apr 20, 2011 | Eureka 4495A Bagless Upright Vacuum
What filters do i need for the eureka the boss bagless vacuum w/widetrack modal 4495
There is a Cassette Micron Filter 60696.If you have a HEPA cartridge filter you need EUREKA's HEPA part 61500.In earlier models there is a micron filter instead of a HEPA filter--for that you need EUREKA's Micron part 60801. But if you have that HEPA filter, the manual says you have to use the HEPA filter to achieve the closed HEPA filtration system again.
Dec 10, 2010 | Eureka 4495A Bagless Upright Vacuum
The handle for my Eureka 5893 AVZ was getting very hot. Finally, the wires around the switch melted and the vacuum will not work. What is wrong? Is the switch bad? Nothing else appears to be wrong.
usually if a connection gets hot enough to start melting it is usually a loose connection or high current. more than likely the switch is bad if you replace it with the same type of switch and it gets hot check the motor. make sure it is clean and isn't jammed
Nov 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Oct 02, 2009 | Vacuums
New Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Jun 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka Boss Smart Vac 4870 evidentally overheated. Allowed unit to cool and observed a spark/smoke at outlet when it was replugged into the power outlet. Unit will not power up now. Circuit breakers in...
The wires leading to the switch inside my Eureka 4870 are fried...black and melted. Don't know why that happened, but it may be what is happening to the others listed on this site as well.
Dec 18, 2008 | Vacuums
Belt
Turn vac over, take out 4 to 5 screws and the top cover will come off. The belt is a cogged belt #72393 and goes between the brush roll motor and the brush roll.
Nov 14, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
1,740 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
