Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Error Message I have a DeLonghi Pinguino PAC L90 portable air contitioner - last night there were thinderstorms and the electricity went out for a second. Now the unit flashes a message "Fsomething (looks like an L with a line through the middle)". I have unplugged the unit for several minutes but the message still flashes when I plug back in. No response when I depress any of the buttons on the unit. Is there a reset button hidden somewhere? Is there a more serious problem? Help!!
  • Anonymous Mar 24, 2014
    So I turned on the dehumidifing function of my Portable delonghi PAC125 heatpump, woke up in the morning to see a little red flashing light by the power button (the red light with an ! mark above it). It looks bad. This is a portable aircon that was bought less than a month ago! Is it broken ?
    Problem Solver:
  • 9 Answers
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Posted on Jun 08, 2008
I have a DeLonghi Pinguino PAC L90. When the Ft message comes on I drain the 2 hoses on he back and replace the caps. Each time I have returned to find a large puddle of water under the unit with the Ft message on. Help it is ruining my floor.
Posted on Jul 21, 2009
Hi I have a DeLonghi Pinguino PACT100. I used Suebee88's advice and checked water had been emptied. I found water tray empty but after lots of fiddling found that there was a float on left hand side of tray which slotted into machine which was not fixed in properly. With a little bit more poking and prodding I readjusted the mechanism so the tray fit correctly and hey presto it worked! Thanks Suebee88!!!
Posted on Jun 30, 2009
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
PAC-L90 NOT BLOWING COLD AIR . DO YOU HAVE TO ADD ANY R22 OR FREEON TO THESE SYSTEMS
they all take refrigerant but there are other things like dirty filter or condensor coils that will cause the same problem
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Pac L90
p f PROBE FAILURE
(The probe is damaged) Contact Service Center. From manual.
May 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pinguino PAC L90 is flashing Lt on the display.
It is in Frost Prevention mode - the appliance will start up again automatically once finished.
Nov 18, 2007 | DeLonghi Pinguino PACL90 Portable Air...
FE Light
You need drain the water and then function normally.
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
1,218 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
