Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Paper jam Please can you help me solve this problem? Whenever the Panafax UF-595 starts printing, the paper stops and a message RECORDING PAPER JAM appears. After releasing the paper the situation repeats. Nothing helps till now.
    Genius:
  • 2,120 Answers
Make sure the little black rollers are turning at the exit end of the fax.
Posted on Aug 30, 2008
How do I program phone numbers on Panafax UF-770
Press
Function
72
set
set
press a position on the soft pad such as ...01
enter fax number
enter name from letters on the soft pad
set
continue as above
when done press STOP
press
Function
62
set
print out directory names and numbers
press function
67
set for a directory sheet.
Oct 08, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
I bought a panafax-uf790 about 2 years ago. Now I am having the worst paper jam problem. It would always stop at the same place and record paper jam. I've constantly remove the paper and it keeps giving me...
Just a suggestion, Try the following, obtain a compressed air canister, or a compressor filled with air, open the unit from where the paper feeds and ejects after printing, blow the compressed air through the feeder and the ejection side, turn the rollers if possible whilst doing this.
May 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Incoming faxes do not show time or date
function-7-4-start-9-start-2-start-stop
this should print the time and date on the paper
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax uf-S1
See if there is a "slider" on either side of the machine.
Oct 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Date and time adjust
to fix the time and date press function-7-1-start-fix the time and date-start-stop
good luck
Apr 17, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax PX-150
Every time i try to find the panafax px-150 it goes on panafax uf-595, so it must be the same way to program the date and time..
- FUNCTION key + " 7 "
- " 1 "
- " SET "
- Enter new date and time : ex: 03............Month
26............date
2008............year
1900............time
If you make a mistake just use the arrow to move the cursor to the incorrect number, then overwrite it.
- " SET " key
- " STOP " key
Hope it help you!!!!
Mar 26, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
217 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
