Question about BenQ PE8700 Multimedia Projector
PE8700+ Hello! I have a Pe8700+ with just over 1000 hours on the bulb. In start up the power goes on and the unit tries to start up, but after a few tries the lamp light flashes red 3 times. There is no light projection at all. I tried removing the bulb and reinstalling to no avail. In looking @ the bulb, it doesn't look like it is burnt out. I called Benq and they said it would need a new bulb. I am concerned it may be something else and don't want to have to buy a bulb and then find out it is something else, may just buy a new 1080p projector instead. Please assist? Thanks Darren
  • 1poolboy Mar 10, 2009
    light flashes red three times wont come on
IT IS YOUR BULB,A NEW BULB WILL COST ABOUT£300 TO £400 POUNDS NEW 1080P PJ A GOOD DEAL MORE.
UP TO YOU BUT IF YOU GO FOR A NEW PJ LOOK AT THE PANASONIC 2000E, IT IS ONE OF THE BEST YOU WILL FIND AT ITS PRICE POINT £2000.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 05, 2008
Can I replace the fan and how do I do it for a Benq PE8700
If the lamp LED flashes red, it indicates that the front cover is not installed properly, the fan is not working, the translation board is defective or the ventilation holes are blocked.
The first thing I would try is to remove the lamp assembly and try reinstalling. (Did you purchase a genuine BenQ lamp assembly)?
If ok, you can download a service manual here (but be advised, this is not for the unqualified. You should seek repair through your dealer).
Elektrotanya for electronics experts
Jun 16, 2017 | BenQ PE8700 Multimedia Projector
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
In a benq PE8700 DLP projector, the lamp bulb comes out in a casing, held with 3 screws. All is good here. I remove it and I want to open the casing to ONLY replace the bulb + cable...cuz it's much...
Buy the new casing if you can not disassemble the case then it may not be serviceable. If you can disassemble the casing then you must find the correct bulb, risky proposion. spend more and get the correct casing replacement part.
Nov 03, 2010 | BenQ PE8700 Multimedia Projector
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
New bulb installed and it takes 10 plus minutes to start
Exchange the lamp under warranty...
You've tried almost everything else.
It's not that uncommon to experience "infancy failure" with a brand new lamp.
If the problem persists with the replacements replacement then I would suspect the Lamp power supply (Ballast) is failing.
Dec 14, 2008 | InFocus ScreenPlay 4805 Multimedia...
Lamp replacement
Hi there
Make 100% sure that your lampdoor is closed properly because there is a little swith on the lamp door that supplies the power to the mashine ( only when pushed in ) You'll see on the lamp door there is a pin that stands out - that pin pushed in the switch when the lampdoor is closed thus supplying power to rest of the components.
Apr 10, 2008 | BenQ PE8700 Multimedia Projector
Benq PE8700 - Won't Power Up
Hi there
Trust me that the Mainboard needs replacement.
I am very familiar with the PE8700's as I am a ASP Technician for BenQ.
Visit www.BenQ.com and look for the link to your country - you should be able to allocate a Approved Service Provider.
Must warn you that the Mainboards on these models are quite expensive.
Mar 29, 2008 | BenQ PE8700 Multimedia Projector
Benq mp6100
If this problem happen with a particular laptop then I suggest that you you change the setting of the laptop you are using. Go to Start=>Control Panel=>Performance and Maintenance=>Power OPtion=>Power Option Propreties=(click on Hibernation Tab and uncheck Hibernation box).
While on the Power Option check the time on the SYSTEM HIBERNATION.
Good luck
Dec 25, 2007 | BenQ MP610 Multimedia Projector
BenQ PE8700 Multimedia Projector Logo
272 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
