Question about Sony PlayStation (PS) Console
Conversion converting ps1 pal system to ntsc
  • esl1213 Nov 06, 2008
    How can i convert PAL to NTSC?
  • phoenixking Jan 30, 2009
    My Aunt sent me some games from Pakistan and they aren't working on my PS1. The owner of a store told me I have to insert a special chip in it.
Call sony tech support does any know where i can some ps one greatest hits
Posted on Sep 18, 2008
My tv has NTSC system but our local transmission is pal system. so picture is black & white and has no audio
hi,
It seems you are going to have to buy a PAL to NTSC converter box, check out the following info i got from eHow.
NTSC, or National Television System Committee, is the system used to broadcast television that is still analog in North and South America and parts of Asia. PAL, or Phase Alternate Line, is one of the other two analog broadcast systems used in much of the rest of the world. If you are in an area that can pick up both, but your television is made to receive only one of them, you can buy an PAL-to-NTSC converter that will allow the correct input to your TV.
Purchase a PAL-NTSC converter. Most mid-range converters will convert back and forth between either system, so if you're not sure which system your television picks up, you can buy one of the dual converters. See the References section for an example of a mid-range converter. When you purchase, choose either 110V or 220V power source, and which country you are ordering from (you will need the appropriate power cord adapter for your country).
Plug the included connector cord from the "Input" (or possibly "Antennae") jack on the back of your television to the "Output" on the converter. Also, plug the power adapter into a floor jack or other power supply.
Move the Input switch to PAL and the Output switch to NTSC on the converter if it is a dual converter. This will enable you to receive PAL TV signals and convert them for your NTSC TV.
Read more: http://www.ehow.com/how_6281541_convert-pal-ntsc-tv.html#ixzz2tSt08zQt
Feb 16, 2014 | LG 32LG30 32 in. LCD HDTV
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
Does kodak zm1 record in pal or ntsc
It's neither, really, it's 640 x 480 @ 30 frames per second. The assumption these days is that you're going to keep your movies on your computer and play them there. However, if you're considering converting your movies to a DVD, or some other format that uses PAL or NTSC, then your answer will be "NTSC" because the conversion from ZM1 to NTSC will be painless, whereas the conversion from ZM1 to PAL will lose one out of 6 frames, resulting in very slightly stuttered motion.
Mar 22, 2011 | Cameras
Hello! thnx for assisting me! I am having problems connecting my canon zr20 mini dv camcorder with the laptop.I got my camcorder in the usa but I live in europe and im having problems also converting from...
Most laptops use a 4 pin firewire connection as does your Canon.
Get a 4 pin to 4 pin firewire cable to connect. I assuma it's a PC and not a Mac, so use Windows Movie Maker to capture.
All editing applications can be user selected for PAL or NTSC, so stick with NTSC in MMaker.
You cannot convert video standards sucessfully simply by selecting PAL if the source is NTSC. You require specialist software or hardware conversions.
As a side point if you create an NTSC DVD it will play on PAL equipment.
Mar 04, 2011 | Canon ZR20 Mini DV Digital Camcorder
My PS1 PLAYS BLACK AND WHITE TOO...
you will need to get it chipped so it can play pal and ntsc games and will display in colour but you must also check that your tv is compatible with pal and ntsc.
Sep 16, 2009 | Bethesda Softworks Black & White
Philips dvd 3445h doesn't seem to support pal format
You would have to either convert the DVDs to NTSC by ripping them to your computer and using conversion software, or you need to get a player that supports PAL and NTSC. Phillips has players that do both NTSC and PAL but it sounds like the one you have doesn't.
I have a Phillips DVP 5140 that does PAL and NTSC and is region unlocked.
There are other players on the market that do support it, but you will have to look around a bit.
Best of luck
Jan 04, 2009 | Philips Televison & Video
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
You might need to input a code on your VCR Remote. Try looking it up on the Internet.
Jan 13, 2008 | Aiwa HV-MX100 VHS VCR
Conversion of PAL (B) into NTSC
you will need a pal/ntsc digital video converter
Dec 01, 2007 | Sony KP-53S65 53" Rear Projection...
Sony PlayStation (PS) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
