Question about Goldstar MA-2117W / B 1150 Watts Microwave Oven
I actually have a MA-2003W/multiwave/1150 watt, microwave popcorn problem
Whenever i try to make microwave popcorn; the square metal thing on the inside right of the oven, behind the area where the light is; gets white hot and i can basically see what seems to be a light bulb or electrical short right through the metal. When it makes this bright light, it also makes a very loud buzzing sound and if i let it continue to run, i have seen smoke come from the metal piece on the wall. Obviously i don't let it run at all now that the smoke has started, have any of you heard of this before? I bought the microwave a long time ago and don't have the manual to check troubleshooting. It does the same thing whether i use the popcorn setting or just manually set it to run on high. Once in a great while i will get a bag that will pop without any problems, but it's like there's something in the bags that is metal i'm guessing?
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: lightning inside microwave oven
You better be carefull my friend or you will start glowing in the dark!! LOL Just kidding. But I wont kid about how dangerous that metal cylinder can be with the holes in the top. Thats the magnatron. It has very high voltage going to it and you should never ever touch any wires going to it even if its unplugged as theres a capacitor in there that holds a charge for a time. f the oven is over several years old, Im sure the magnatron will cost more then a new oven, after you add labor and such. It just migfht be time to upgrade to a new microwave?? Good Luck
Posted on Aug 11, 2006
My 24lit. LG MG-583MC multiwave microwave with grill very slow to cook i.e. A cup of cold coffee takes about 2,5 min to boiling point.
sounds like its not on high power.. Some microwaves have a popcorn button..This is usually automatically a high setting.Try putting your water in then hit popcorn...If the water heats up faster then your power settings are set wrong. You just need to change them. Your not set on high power..
Jan 12, 2018 | LG Microwave Ovens
I boiled a egg in my microwave multiwave oven 750 watt and after 3 min the egg blasted and the oven stopped working. what could have happen and how can we fix it at home?
Unfortunately this is one of the worst things that can go into the microwave, when it blasted it covered everything on the inside including the magnetron and door switches. The cost will be high because chances are high the magnetron is damaged and the interior cavity is covered in egg not to mention the door latches, I would recommend replacing the whole unit.
Mar 30, 2012 | Microwave Ovens
Manual goldstar multiwave 1000W
Can I use aluminum foil in my oven
May 18, 2010 | Goldstar MA-1011 Microwave Oven
It catches fire whenever anyone cooks microwave popcorn
you are working with a higher wattage microwave. Reduce the power to 70% or even 50% and increase the cooking time
Feb 17, 2010 | Goldstar MA-1011 Microwave Oven
HOW DO I TO GOT THE METAL CASE FOR A MA-1020W ,
That part may not be available anymore.
I would call Encompass toll-free at 866-779-5835.
Good luck.
Sep 25, 2009 | Goldstar MA-1020 850 Watts Microwave Oven
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
No instruction manual
If that's MA-1417W, you can download the owner's manual here.
You will need the free Acrobat Reader to view or print it in case you don't have it.
Jan 02, 2009 | Goldstar MA-1417W 1150 Watts Microwave...
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Goldstar
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, you may have a failing keypad. It can fail due to age, moisture, etc.
PLEASE Let us know if the hard reset doesn't fix it.
We have the service manual available to us.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | Goldstar MA-2117W / B 1150 Watts Microwave...
Hole in the microwave
Where exactly is the hole in the microwave?
If it's a hole in the actual metal chassis of the oven, it should not be used and you should contact Dacor customer service:
http://ww2.dacor.com/services/index.asp
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced. Dacor can help you find one.
Dec 05, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Goldstar MA-2117W / B 1150 Watts Microwave Oven Logo
228 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
