Home | Yamada | DVX-6600 DVD Player | Yamada 6600 - Not wor...
Yamada DVX-6600 DVD Player
Problem for Yamada DVX-6600 DVD Player
Yamada 6600 - Not working at all!!!! please help me :-)
By kikkalondon on Jun 05, 2008
Hi There,
I bought it from a friend of mine, that now is come back to italy, he said that it's perfect and it can play any dvd divx etc etc...
I don't know why but at his home it was working, we tried it togheter, but with me it doesn't work (probably because I'm a girl :-)) joking).
As first I've connected the scart to the divx and the TV, well, the Tv showed the yamada divx on the video...
I tried to insert the first divx and after a while "loading" it says "no disc"... I changed thinking that it could be a used divx so may be not perfect... and also the 2nd, 3rd, 4th, divx disc wasn't recognized by the player... that's strange!
At the end it tried with a DVD bought the day before (so original and new) but as always after a while "loading" it says "no disk"... that's impossible!
How can it happen?
So I tried changing the setup menu... with a lot of combinations... but it doesn't work as well...
Can anyone help me?
I don't know if I need other cables or not... I've connected the scart (TV to YAMADA) and after the player to the plug in the wall... is there anything else to connect?
My TV is a big old-fashion mitsubishi in color (so no plasma or other new)
Pleeeaseeee... I'm desperate...
Thanks
Apologies for my bad english... I'm an italian in london so sometimes I make a lot of mistakes
Cheers
Caterina
Same Problem
Feb 25, 2009
-   no disc error, hdd is not starting up. no menu tested with discs from previous use, still will not recognise and will not spin up dvd to use cleaning disc. Very annoying fault. -   Guest
Feb 06, 2009
-   my player developed the same problem unexpectedly. i've opened it up and it appears the motor that makes it spin is finding it hard to get it going (if you give the disc a little flick to help it along it will spin and proceed to read the disc). either the motor is tired or the voltage/power to it has dropped. i have no idea how to make it work fully when closed up. -   yamada6600
Aug 05, 2008
-   I have just the same problem on my Yamada. Yesterday I took it on again after some months. At first it suddenly worked for a while but then it began again, loading...no disc...
I tried to find possible bad connections and solderings with hot gun and cold spray, no help. I measured the voltages of power supply, they all are a littlebit lower as said on board bu I think it is not the problem.
-   erkkilau
Popular Solutions for Yamada DVX-6600 DVD Player
Questions and Unsolved Problems for Yamada DVX-6600 DVD Player
Do you recommend Yamada DVX-6600 DVD Player?
Answer
Answer
iv got a yamaha 5 disc CD changer and it will not do nothing the only thiung that it will do is the... (More)
Answer
yamada hard drive recorder,model dvr 9000h. i am unable to open the dvd slot to insert a disc. any... (More)
Answer
Bought in Britain 1 Year ago. The disc tray now refuses to open have checked on line other people... (More)
Answer
I want to burn uncopyrighted DVD to my hard drive? But cannot do this. Please help? Any suggestion... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Yamada DVX-6600 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
