Setup proceedings to direct TV is very difficult to type in by this window. If you wish to get more setup codes, three digits, four
digits or five digit ones, check this link.
Pull up older posts. Setup code
list and setup instructions to some popular model remote controls are given.
Press and hold the MUTE and SELECT keys at the same
time until the green light under the TV position flashes twice, then
release both keys.
Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly, the green light under TV flashed
twice.
Aim the remote at your TV and press the PWR key once.
Your TV should turn off. If it does not turn off, repeat steps 4 and 5,
trying each code for your brand until you find the correct code.
Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
Yes philips and samsung universal remotes can be used with truetech tv's. Trutech is a daewoo product so using a daewoo so try the daewoo codes and one should work for your tv.
Tried various blog comments and came up with one that semi-worked. For the above LCD TV DVD combo (Trutech Model PVS31170551) the code for directv is 10030. It allows you to control the TV portion of the LCD with the Directv remote but it does not control the DVD part of the LCD.
I'm 90% satisfied with the solution, thanks to the bloggers.
Try LG, Goldstar, or Vizio codes. Otherwise, visit the product website. If you have a Trutech LCD TV, you can check at http://www.1800customersupport.com/trutech
