Question about HP DeskJet F380 All-In-One Printer
Paper Even though there is paper in the tray, it says "No paper"
  • FingF380 Jun 17, 2008
    Having same problem with my F380, ie paper loaded but refuses to print and no paper light is flashing!!! Help!!!
  • Anonymous Jul 02, 2008
    Same here! I kept reloading paper into the tray, but the screen still says no paper. Any help would be highly appreciated!
    Thanks
    Novelist:
  • 106 Answers
the issue that you have right now might something to do with the paper feeder rollers.. or it might be the printer driver. here are the things that i want you to follow.
TRY TO RESET THE PRODUCT
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Note: if still doesnt resolve the issue, go to the other steps.
SOLUTION II: TRY TO CHECK THE PAPER CONDITION.
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper. NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step.
TRY Cleaning the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
Note: if the issue still not resolve, please give me a feedback so that i can go ahead and give you another possible solution.
thank you,
best regards
adonscott
Posted on Jul 03, 2008
How can i get a canon 880 series printer to take paper
There is usually a flashing light for the paper tray and while paper is in hit the button and it should feed the paper through to let it know that there is now paper there. First you must make sure that if there is more than one feed-tray that the proper one is selected that you have the paper in.
Aug 28, 2014 | Canon PIXMA Office Equipment & Supplies
Hi, my lexmark e260dn "load paper" light stays on even though paper is loaded. please help
Please check if the paper guides on the paper tray are correctly positioned. For example, if you are using a letter sized paper, make sure the guides are set to 8"x11".
Dec 20, 2012 | Lexmark E260dn Laser Printer
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Brother HC4040CN displays error message NO PAPER even though paper tray is full. Will not feed paper from Main tray.
The paper sensor flag above the paper tray on the printer chassis is either stuck or has broken of. You need to take the printer for repairs.
Aug 04, 2009 | Office Equipment & Supplies
Panasonic Workio 1810 - Tray 1 Add Paper Message
First why is the tray set for size A4 Paper. That is metric size paper for oversea locations. Should be set for 81/2"x11, or 11"x81/2.. is there any paper stuck behind the 1st tray? are the guides that hold the paper in place in the draw snug up aganist the paper in the draw. is the bottom sheet of paper in the stack/rem of paper benton the edge. All sheets of paper in the draw must be flat.
Jul 20, 2009 | Panasonic Office Equipment & Supplies
Apple 16/600 Laserwriter reports out of paper but its not
It's the sensor from tray fault. Try to blow with air spray to sensor, maybe is dirt with paper dust and need clean.
All the best and Happy New Year !
Dec 29, 2017 | Apple LaserWriter 12/640 PS Plus Printer
Says add paper to large tray even though it is full
Depending on which large capacity feeder you have.
If you have the one that is on the bottom of the machine, make sure there is a gap between the paper in the front and rear of the paper tray, There is a black plastic guide in the middle of the tray that may be being caught by the paper.
If you have the large capacity feeder on the right side of the machine then most likely the black actuator that tells the machine the tray is full has broken or the sensor is bad,
Feb 12, 2009 | Toshiba E-STUDIO 650 Copier
Its saying the paper tray is empty even though there is paper
the problem is with the paper sesor in the paper tray. It must
be under the tray lift mechanism.
This is located in the right front part of the paper tray.
Nov 18, 2008 | Brother MFC-8460N All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
71 people viewed this question
Ben Johnson
