Hi Buchi
Do you mean you get a small desktop inside the screen surround by blank space or black?
If so then I think you are reaching the end of the eMac's life.
These machines have been very good overall. Some had the dreaded capacitor problem , but Apple fixed that on affected machines by replacing the motherboard.
I have of late though seen a few eMacs with display problems. I have one here now with a very pink display - as a computer it works fine, but the display (or display electronics) is giving up.
Unfortunately it is probably not cost-effective to try to repair these machines.
One thing you can do though is connect up an external monitor.
See if you can borrow one and plug it into the video out port (the socket right at the end of the line of connectors on the side of the eMac) You'll need a suitable adaptor though.
`If that display is fine then the problem is with the tube itself, but if the problem is still there, then then the issue is probably the video board - again not worth repairing.
I have no experiense with apple/mac products, but you may be able to boot up into safe mode and do some system repair.
There is a guide here http://support.apple.com/kb/ht1455
You should format the internal hard disk and install a clean and fresh version of Mac-OS anyways and create a new user-account. If there is no install-disc included, try calling Apple, tell them your eMac's serial number (All eMac's have their serial numbers printed inside the disc drive door), and ask them if they have any replacement install discs for your model of eMac. Check out the Apple eMac support page or the Apple eMac support forum for more informations.
On the keyboad, above the numbers are the function keys. Depending on the keyboard being used, there is a key that changes the brightness of the screen. You can also go into your System Preferences under Displays and change it there.
OK - first, crossover cables let you network PCs together without a switch or router. I would strongly recommend returning the crossover cable and buying a router so that you can use both computers on the internet at the same time.
Second, the eMac monitor can not directly be used as a monitor for your G4 - it's not built that way. However, you can use Screen Sharing on OS X (if both have Leopard) or Apple Remote Desktop software (if you buy it) to remote control the G4 using the eMac.
You will DEFINITELY need a monitor on the G4 in order to set it up at all, so I hope you have that.
Keep in mind that you can buy, for less than $200, an LCD screen that is larger and better quality than the eMac, and it would leave the eMac useful as a second computer. Since the eMac is unlikely to work at all with Leopard, and you'd have to buy Apple Remote Desktop, you're going to spend less money by buying a separate screen for the G4.
