Question about Logitech Vantage USB Microphone for Nintendo Wii
My microphone won't work with my computer?
I put the microphone in my computer's usb outlet it detects it but no sounds come out of the speakers when i talk into it
  • 3 more comments
  • Anonymous Oct 12, 2008
    We have the same problem. No sound whatsoever.
  • Anonymous Dec 27, 2008
    Same
  • shannonquinn Feb 16, 2009
    Same prob
  • Anonymous Mar 01, 2009
    Same
  • mikey1991 Mar 29, 2009
    i do the troubleshooting and everything and it works as long as i have the troubleshooting open but after that nothing...
M2Tech1
  • 313 Answers
SOURCE: the microphone is not detected
you cn check the connection b going into the properties of your sound card page and go to the section for input check if the mic shows up have you any drivers loaded for the mic... if you go to setting then control panel look for the sound and audio box there is block there for speech check you mic is selected.. you can try connecting via afront panel usb port as well or via you sound card inputs on the back panel
Posted on Jul 31, 2009
I can't find where my microphone goes
Is your computer a laptop or a desktop? How old is it? Which make/model of computer do you have?
For an older desktop, the microphone input will be on the back of the computer. There are usually three 3.5 mm jacks for audio connections. The pink connector is for the microphone. The black connector is for Line In and the green is line out (speakers). Often they are towards the far side of the motherboard connections from any PS2 (keyboard and mouse) ports. Otherwise, they will line up with one of the card slots.
Newer desktop computers often have additional audio ports for surround sound. However, the pink jack for the microphone is standard. If the computer has front audio ports, you may find that the same color labels the jacks. Otherwise look closely at the icons next to the ports. These will be in addition to the back audio ports.
Laptops can have the audio ports on the front, back or side depending on the model. There will be a small icon with a stand microphone indicated for the microphone port.
If you have one of the newer USB microphones, plug it into an available USB port.
If the computer has no working audio ports, either get a USB microphone or add a sound card.
I hope this helps. If you add a comment with your computer's brand and model number, I'll try to provide the exact audio port details. (There are some computer motherboards that do not have on-board audio and you will need a sound card.)
(on Windows computers, you may have to change the default audio input. Click Start > Control Panel > Hardware and Sound > Sound > Manage Audio Devices. (for Windows 7) For other versions of Windows, you may find slightly different titles in the Control Panel.)
Jun 24, 2011 | Compaq PC Microphone (Black or Beige)...
Tip
How to play computer sounds through microphone
<p>There may, of course, sounds from a microphone, because there is a speaker, but you can use sounds from a microphone or something speakers connected to the microphone system is played. Computer games, but might sound a bit complicated because they usually lead to loud sounds into the microphone to a number set. <br /> <p><br /> <p>1. Find the computer that you want to play sound. Go to Control Panel and click on "Hardware and Sound." Under "Sound" in "Changing the system sounds." You can access various Windows sounds by selecting them and clicking "Test". <br /> <p><br /> <p>2. External speakers to the sound card or audio output on a laptop. With active speakers is recommended, the stronger the better. Set the microphone in front of the speaker. <br /> <p><br /> <p>3. Connect the microphone and play the sound from computer speakers. That should pass the microphone for recording or performing live. <br />
on Jun 22, 2011 | Audio Players & Recorders
I purchased a R31S Samson Microphone and it cant be detected when i plug it in to my computer microphone jack. What is it to do?
A dynamic mic connected to the your computer's mic jack is an analog connection. So your computer won't give a notification that there's a mic connected. However, you can view input levels through the default windows mixer of your sound card or any program or application installed on your computer that has the capability. Had it been connected through usb or firewire, it would be digital and you wold be notified that the device had been detected via device drivers etc.
Hope this helps
Apr 09, 2011 | Samson R31S Microphone
When i plug my g-track in it cancels all audio and i cant hear any sound from my speakers.
sounds like you have put the connector in the phones out socket check it is mic in or audio in you have put it in
Jul 18, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
The microphone is not detected
Jul 31, 2009 | Logitech USB Desktop Consumer Microphone
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Sound problem
ok well u need to save the music first den export it n save it on to ur computer den open it wit ur windows media player or wich ever player u have
Aug 04, 2008 | M-Audio Producer USB Microphone with...
Microphone is not working
1-adjust the overall volume by pressing fn+f 5 hotkeys
2-adjust sliding mixer controls by doubleclicking the speaker icon
3-disconnect the headphone jack to enable check of internel speaker.4-confirm that microphone plug is proper connected to mono mic jack.5-confirm that microphone is selected as recording source in control panel----multimedia and recording level is adjusted.
confirm that sound source is selected in control panel----multimedia
confirm that headphone connector connected in right postion
Jan 24, 2008 | Compaq PC Microphone (Black or Beige)...
Michrophone
which program are you useing?
its possible your mic is on mute so no sound gets throught.
check the speaker icon next to your clock
then press settings and properties and click on regording. then ok. then make sure the microphone is not muted and the sound level is high enought.
Oct 14, 2007 | Logitech USB Desktop Consumer Microphone
Logitech Vantage USB Microphone for Nintendo Wii Logo
229 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
masterwest
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
