Question about Compaq tc1000 Tablet PC
Monitor symptom of damage moniter?
  • Wendy Roman May 11, 2010
    What do you mean by damage? Like scratches, cracks, clarity issues?
    Problem Solver:
  • 5 Answers
If your LCD monitor has damage it could be in three forrmats:
1) Damage LCD ribbon. The screen will power up bright white and you will see random strings of color in diaganol or horizontal streaking slowly across your screen.
2) Damaged Liquid Crystal Container. The thin glass/plastic may have ruptured due to an impact on the screen. You will see sharp jagged lines and maybe a partial post screen, but where the sharp "jaggies" are, are now permantly broken
3) Nothing on screen. This indicates that your internal CCFL (oh I love LED technology) tubes have now lived their life and will not ignite. To test this method, hold a very bright light to the screen and see if you can see any logos (Compaq/HP/Win Xp loading screen...etc)
If you can see something, your screen is fine, but there is no light behind it for you to see.
Hope this helps.
Posted on Dec 19, 2009
My tabler screen is damaged is there an adapter possible output onto monitor
Depending on the model it may have a mini HDMI port. Check the specs of your model on the web. It may require an adaptor.
Jul 01, 2016 | Tablets & eReaders
Blank Screen
The bad thing about this is that it could be a software related issue or a hardware issue. If you're willing, you can disassemble the unit and check for a damaged or loose connector to the monitor. If there doesn't appear to be any issues there it may well be that the screen has gone bad or there is something wrong with the driver/setting on the unit itself that is causing the screen to saty off. I'd move forward with the hardware issue first though.
Jun 09, 2007 | Toshiba Satellite R15-829 Tablet PC
Hannspad 13.3 inch does charge beyond 53% either on or off
Older tablet batteries can begin to give out after less than two years. If a newer tablet shows this symptom, it could be that the battery monitoring software has lost sync with the battery. If a complete discharge and recharge cycle shows the same result, then a failing battery is likely. Tablet batteries are technician replaceable only and then only if they can be obtained from the MFG.
Apr 10, 2014 | Tablets & eReaders
I need to hook my kyros android to my computer moniter
https://www.youtube.com/watch?v=FE739rppeJI
example of android connection to monitor ,youll need HDMI cable possibly with mini HDMI on one end depends on your ports on tablet.
Feb 04, 2014 | Tablets & eReaders
How do I replace monitor?
Hi Ken,
Replacing a monitor on a laptop should not be attempted unless you have prior experience with it. Laptops are very tricky and attempting to replace the screen yourself could damage the laptop further. If you are comfortable attempting this, please let me know and I will help guide you through it, otherwise please take it to a reputable computer repair store for assistance.
Cheers,
aexl
May 22, 2012 | CTL 2go Classmate Convertible Pc Nl2 Dark...
The pc star ok but it keep given me a white screen
It is possible that the problem in the slide card that beats screen located on the main board and the faults which also appear on-screen plasma appearance of a white image on the screen or the colors are without any data. Easy to verify the integrity of the slide card that beats the screen by pressing of Touch Pad or the left part of Keyboard to the East, including notes. When connecting to an external monitor with no emergence of data
Among these symptoms we see that it is clear that the device temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
Jul 14, 2010 | HP Pavilion tx1220us Tablet PC
My pavilion 1410 starts up but screen is blank, all lights are on except wireless is amber not blue. I closed the lid before it shut off, I have charged it but still will not come on. Don't know if windows...
It appears this is a lemon laptop as i have heard of dozens of people with the same exact symptoms "including my family" . I think every one should get hp to fix them or they should have to repay the consumer. sounds like defective engineering and class action suit. I own 4 Dell laptops and 1 Dell desktop and they all work but the hp laptop and the hp desktop we have both failed shortly after warrantee expired.
Oct 23, 2009 | HP Pavilion tx1410us Tablet PC
Travelmate C300
Sounds like it. . . (power pin problem). I use a Cable Retention Device like the one in this video to keep from damaging the fragile connector. . . .
Dec 07, 2007 | Acer TravelMate C302XCi-SP2 (TMC302XCISP2)...
Compaq tc1000 Tablet PC Logo
245 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
