Question about HP PSC 1110 All-In-One Thermal Printer
Refilling HP 56 Cartridge
Please help. I've refill a cartridge still in use for the first time. (my first time refilling too). Its not printing. When I put it in hot water for few seconds its printing one page then nothing. There's 3 holes on the cartridge. I've put ink in al three holes. 5 ml's in each hole. What did I do wrong.
    Novelist:
  • 208 Answers
USING THIS TYPE OF REFILLS JUST ISN'T A GOOD IDEA. THE INK IS NOT THE SAME AS HP CARTRIDGE INK AND YOUR PRINTER WAS MADE FOR HP INK, NOT SOME GENERIC BRAND. THE FACT THAT IT DOESN'T WORK UNLESS YOU STICK IT IN WATER, ETC. SHOULD TELL YOU SOMETHING IS WRONG HERE. REFILLING IS MESSY, AND CAN CAUSE LEAKS IN YOUR PRINTER AND REALLY MESS THINGS UP. THE BEST BET IS TO USE THE PROPER INK CARTRIDGE WITH YOUR PRINTER. THATS THE TYPE OF INK IT WAS DESIGNED FOR.
ARCLIGHT1217
Posted on Nov 05, 2008
I have just had my cartridges refilled and now have reinserted them in printer but it keeps saying remove and check colour cartridge (which i have done lots and lots of times), help please
Ink cartridge contains Ink tank, electrical circuit & print nozzles.
Adding ink to ink tank is called refilling, if any fault in circuit/nozzles will indicates the cartridge error.. Before refilling check cartridge health condition.
In your case its sure that cartridge faulty, go for new one..
Nov 10, 2012 | HP PSC 2355 All-In-One InkJet Printer
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp F4280 can't recognize a black cartridge after refilling it. What can I solve the problem? Please help me!!
If the printer not recognize it, that mean the cartridge are failed electrically and you need to replace it.There is an another option.After refilling printer will recognize cartridge like empty but it will printing.
Nov 17, 2009 | HP DeskJet F4280 All In One Printer InkJet
Even after refilling the cartridge, printing is not clear
Refilling cartridges on _quality_ printers is not a wise solution. The makers of printers like Hewlett Packard spend thousands of dollars to formulate an ink to match the print head and printer. Then you buy a cheapo version of non-descript ink and refill their cartridge to save money and complain about the result. Buy a new HP cartridge, clean the nozzles, print a test sheet and post the results please.
Nov 17, 2009 | HP LaserJet 6L Printer
After refilling i attached the cartridge but not printing printer showing "check cartridge" i have done refilling like this 3 times without any problem but this time i am facing this problem .Kindly...
search for the specific cartridge you have and keywords such as "refill, reset expiration, contacts" for instructions on how to fool the printer into thinking the cartridge isnt expired yet. This works for most HPs:  http://www.refill4.com/refillinstructons/cartridges/hp-56-27-21-57-28-22.htm
Jul 27, 2009 | Office Equipment & Supplies
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
HP 56 and 57 print cartridge
The problem cannot be solved even after downloading the HP cartridge compatibility software. The only solution is to buy a new HP cartridge to replace the old one which is still printing pretty good after refilling several times in a year. Perhaps it's the business tactics of the HP company which purposely setting some memory chips inside the all-in-one printer which can record the number of uses of any installed cartridges so in times it will reject that overdue cartridge and fail to respond properly. So the only way we consumers can do is to accept and pay if we want to use the product or curse them or just throw the printer away!!!!!
Nov 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
Recalibrating a refilled black ink cartridge for a photosmart 7960
your printer probably cannot recognize one of both cartridges
clean the contacts of the cartridges and the contacts of the cartridge carrier  with a wet towel
if that does nt work your ink cartridge has probably overheated  because air has left in the cartridge after refilling and must be replaced
check here the right way for refilling
http://www.youtube.com/watch?v=dhDaKSzou50
Sep 09, 2008 | HP PhotoSmart 7960 InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
HP PSC 1110 All-In-One Thermal Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
