Question about Konica Minolta magicolor 2300DL Laser Printer
Cant replace a toner cartridge
For the minolta qms magicolor help
  • 1 more comment
  • Anonymous Feb 13, 2009
    The 2300w does not have a Menu Select button nor arrows. It typically requires the proprietary software that comes with the printer to change toner or check the toner levels. Go to download the appropriate driver for your operating system and it may do the trick. For me it works under Vista but not under XP.
  • Anonymous Mar 13, 2014
    konica minolta QMS magicolor 3100
It's done via the printers internal menu system:
On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Posted on Jun 18, 2008
My konica minolta 2300 prints purples instead of red i have replaced all toner cartridges so the toner levels are ok
it could be problem in color registration.Try to do color adjustment, but also check the trnsfer belt and drum
Jun 05, 2010 | Minolta magicolor 2300W Laser Printer
How do I change the ink cartridge?
This printer is a laser jet printer - so you will be changing the multiple toner cartridges, not ink cartridges.
Page 56 starts the steps on how to replace the toner cartridges.
The front of the printer opens to the right and exposes the toner cartridges for removal.
May 04, 2010 | Konica Minolta magicolor 2300DL Laser...
I just installed 4 new toner cartridges in my magicolor 2300 DL and I still can't print. It is still tellimg me to change the cartridges. Help!
You have to tell the printer that you have replaced the cartridges.
Here are step by step instructions:
Also, check to make sure that you have removed all the tabs and plastic strips from the toner cartridge.
Aug 04, 2009 | Konica Minolta magicolor 2300DL Laser...
Not printing yellow (64% full)
Go to maintenance and purge ur cartridge.Cheeck regularly ur wiper maybe it will cause clog to ur cartridge.
May 20, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
How do you change the drum cartridge ?on a 2300 qms minolta printer
Replacement of the OPC Drum Cartridge
1. Open the Front Door.
2. Remove the Waste Toner Bottle.
3. Lower the unlock lever and remove the Drum
4. Reinstall the new Drum Cartridge
5. Pull the protective sheet of the Drum Cartridge to
the front and remove it.
6. Raise the unlock lever.
Jun 09, 2008 | Minolta magicolor 2300W Laser Printer
Cant get the toner replace promt to hightlight so I can replace it. Tried restarting
install status monitor to computer and from there you can choose change toner X and printer turns the cartridges in right place. or if you cant change that way, then under the front cover there is a switch, look the knobs on front cover and find it, it should be upper left corner, then you can rotate the cartridge manually.
Mar 14, 2008 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Cartridge Removal 2300DL QMS Minolta
magicolor 2300 DL procedures
a)From the display, select the menu “Engine”.
b)Select “Replace Toner”.
c) Select each color toner cartridge from this
menu to remove it.
Nov 26, 2007 | Konica Minolta magicolor 2300DL Laser...
Help replaceing a toner
Here is what you do.... turn off the power, open the door to access the toner cartridges. You'll see the access port to pull the cartridge out. There will be a small picture to the top left showing to use your two fingers to pull it out. Between the pic and the opening there is a square hole with a round plastic tube in the center of it. Take a car or house key and stick it in the hole. When you do, you can now rotate the cartridges by sticking your finger in the individual cartridge holes. Rotate the cartridges until to can freely pull out the one that needs to be replaced. Put the new one in, close the door, turn on the printer... Ta-DA!!
Nov 07, 2007 | Konica Minolta MAGICOLOR 2300W LASER...
Konica Minolta magicolor 2300DL Laser Printer Logo
274 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
