Question about Canon L220 Plain Paper Laser Fax
Keep saying check printer
I am facing the problem with my fax mechine l220 error code appear ##324 and then appear CHECK PRINTER give me the solution
5.5.3.3 ##324 [Rx] Printer section scanner motor rotation rate abnormal 0003-5251
Cause
An internal mechanism is faulty.
Remedy
1) Check the connection between the laser scanner unit (J802) and SCNT board (J6).
2) Replace the laser scanner unit.
3) Replace the SCNT board.
Posted on Jul 24, 2008
Cause
Remedy
Check printer(##322) error in canon fax l220
Error # 322 is a Fuser not heating error. This usually means the fuser is bad or requires a fuser module. This is not something you can test without servicing the unit, so it would need to go to Canon or an Authorized Service Center for repair.
Jul 09, 2011 | Refrigerators
Check printer error ##322
##322 is a common error and it is the fixing unit that's not warming up!U can have it replaced and fixed!
Jan 26, 2010 | Canon L220 Plain Paper Laser Fax
CHECK PRINTER ##330 flashing message
From the message board archives:
Error codes:
## 322 Fuser not heating (Usually Bad Fuser Module)
## 323 Laser Beam detect error
## 324 Laser scanner motor rotation incorrect
## 325 Fan motor inop
## 330 Power Supply (Replace/Repair)
You must turn on error management to have the machine display error codes, otherwise it will just say "CHECK PRINTER".
To turn error management on, enter the following: Press Data registration, #, Set, 00000011, set, stop. Now after the "check printer" message there should be one of the error codes above.
Supposedly, Nation-Wide Repair Service fixes the bad power supplies for $45.00. They can be reached at 800-798-1814. You can also buy one for $148.00 from www.loyal.net I hear. The proper replacement power supply part number for both the LC7000 and LC7500 is HH3-5278 so I am told.
Aug 04, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
##322 error on display
Fixing unit faulty and it can be replaced!
May 12, 2009 | Canon L220 Plain Paper Laser Fax
Fax machine Canon L220
Ok first of all you have to deside how you are you going to use the fax,there is a option for Manual mode,Fax only and Fax Tel mode.
I normally set all my faxes with Fax only mode and then set the incomming ring to 7 rings before it switch to fax.This give you enought time to answer the phone.If you answer the phone and it is a fax you just press the green button.
You load your paper at the vertical tray,this is the last paper tray from thefront.
For sending faxes-put your documents face down in the dockfeeder dail the number and press green button.
Remember to connect the incomming fax line to the "L" jack on you machine and the extention tellephone to the jack with a handset showing on top of it.
Jan 14, 2009 | Canon L220 Plain Paper Laser Fax
Canon L220 Fax ##323 Check Printer
Canon manual says ##323 is the laser beam detector defective. Try to substitute the laser assembly (RG5-3497)
Dec 22, 2008 | Canon L220 Plain Paper Laser Fax
Error Code for Fax Canon L220
You need to service machine and may be your fixing unit is problem
> If that replace Fixing Unit
Jun 19, 2008 | Canon L220 Plain Paper Laser Fax
Canon L220 Plain Paper Laser Fax Logo
341 people viewed this question
old marine
old marine
