Question about Krups Allegro FND111 Espresso & Coffee Maker
No steam comes to milk frother
No steam comes out of the steam exit.
  • 1 more comment
  • trashnfun Jun 21, 2008
    Worked fine last night. Still brewing. But no luck getting anything to come out of the steamer. It will still stop brewing when we switch it over to the steamer, but that's about it.
  • jmerritt Nov 12, 2008
    I have the same problem! My steam valve doesn't work either. Small air bubbles show up in the milk, nothing more...
    Thank you to anyone who can help!
  • BWildered Apr 05, 2009
    Similar problem here: Steamed fine yesterday; just a trickle today. I suspect that a fleck of something has gotten lodged in the steamer circuit. If any steam or water is making it through at all, one thing you might try is running vinegar through the steamer (with espresso lid on to create pressure). Regularly "descaling the circuit" with vinegar, as recommended in the user manual, can help keep the steamer working.
    Problem Solver:
  • 4 Answers
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Posted on Apr 05, 2009
3 Suggested Answers
  • 37 Answers
SOURCE: Frother not working
The frother does not have a vacuum, it uses venturi pressure to draw up milk through a venturi at the top of the steam feed. The milk side is clogged from not cleaning enough. soak in boiling water for a few minutes and try to run it in steam mode for a while... if that doesnt work, a light lye solution will dissolve the milk residue clogging it. neutralize the lye with vinegar drawn through after the clog is gone.
(lye will dissolve you as well as milk... use gloves and don't put your face near it while it's working.)
Posted on Apr 19, 2009
  • 39 Answers
SOURCE: frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Posted on Dec 31, 2009
Hi, We have a Saeco Royal coffee machine and the milk frother doesn't seem to be working. Need some advice as to what could be the problem?
1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Dec 20, 2016 | Saeco Coffee Makers & Espresso Machines
More detail to my question on mal function of milk frother. Coffee making function is working well and I have descaled as per instructions. When I try to use the steam arm there is a pumping sound but...
This might not be the problem , but sometimes , not cleaning milk frother tip properly , the tip gets closed with dry milk. use a needle and push it in the frother tip and see if there is a restriction. hope this helps.
Mar 22, 2015 | DeLonghi Pump Espresso Maker
No steam from Magimix expresso
Has anyone got a solution to no steam from milk frother please
Dec 12, 2011 | Magimix L'Expresso Espresso Machine
The milk frother is not sucking milk from the cup... it appears that the steamer is working as if it is steaming the milk. Any ideas on why the frother tube is not sucking any milk up?
it is clogged with dried milk. Remove the frothing wand from the machine. now press milk froth. you should get a ton of steam blowing out of the hole where the frother used to be. Your frother comes apart for cleaning. pull the chrome tip off, pull the 90 degree fitting and the black milk suction tube off, if it is really dirty you can soak the disassembled frother in hot water with a cleaning tablet. ( the small ones you drop in the brew unit, not the big descaling tab.) also, there is a clear tube with a point on the end of it sticking out of the frothing wand. this is an air admittance oriface. it allows air to enter the hot milk stream and make it frothy and bubbly. if it gets clogged, you will get hot milk but no froth. Your machine came with a spare one in the parts kit.
Jul 04, 2011 | Miele CVA 4062 Stainless Steel
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Frother not working
Apr 19, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
Krups Allegro FND111 Espresso & Coffee Maker Logo
1,287 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
