Rinnai 2001 space heater: stuck dial
The dial was turned to 'off' instead of 'standby'. It can no longer be turned on past 'ignition/press'. Graham
  • Graham Jun 29, 2008
    Thanks for that, I'll try it next time. BUT the problem just disappeared by itself after 24 hours or so!
Mine did a similar thing, when in off position, it would only turn to pilot/ignite, but would not move past this point. I took off bottom cover to locate regulator. where the slector knob shaft meets the regulator, try spraying wd40 in the top of regulator where square shaft goes into reg. There is a saftey lock mech in there, and in my case it was stuck in the locked position. I then worked the knob back and fourth applying alot of pressure, but not enough to break the knob. it worked after a few tries, and lights and functions normally, locking again if pilot goes out. good luck.
Posted on Jun 28, 2008
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
Getting an error code of 11
Error Code 11 indicates an ignition failure. Check that the gas supply is turned ON. Switch the heater to STANDBY and the ON again. If the burner doesn't light or you continue to have a problem contact your Rinnai dealer.
Hope this helps you and thanks for choosing FixYa. Cheers ...
Sep 20, 2011 | Rinnai Vent Free Gas Heater/
Have a rinnae royal gas lok heater. Cant start it after gas was shut off. How do you get the ignition to work and start the pilot light again
When the gas was turned OFF, air got in the line(s) and created an air pocket. This air will need to purged from the system, before the heater will light. It only the shutoff valve on the gas line to the heater was turned OFF, it will be easier to purge. If your Rinnai heater has manual ignition rather than electronic ignition. Holding the control down in the Pilot position, will eventually purge the air. If you have electronic ignition, continually trying to light the unit will do the same thing, but take longer to accomplish. Consulting your Rinnai will also help you with this situation.
Jul 28, 2011 | Rinnai Heating & Cooling
Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai gas heater loud noise on ignition
It may be, Rinnai suggests a maximum length of about 13 equivalent feet of venting including elbows. Add 6 feet for every 90 degree elbow. If the vent is longer than this it is taxing the combustion fan motor and it will start giving you error codes and will not ignite. Remove the trim panel from behind the heater and find the flexable air intake pipe. Temporally remove it from a fitting and test the unit a few times to see if the unit starts quieter. This procedure will be taking room air into the heater for combustion and circumventing the direct vent feature of the heater, not a fix. Have you had the gas pressure tested? It gould be that! You may wish to consider relocating the heater and fire your installation contractor for putting you in this predicament, not Rinnai.
Nov 05, 2009 | Heating & Cooling
Our heater wont light
your in the wrong section this is airconditions
Mar 27, 2008 | Heating & Cooling
Heating & Cooling Logo
442 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
