Question about Lands Phones
Car kit - Lands Phones
  • Lands Phones Master
  • 13,433 Answers
Car kit?
Posted on Jun 05, 2008
Do I need to change rear shocks after a lift kit
SilveradoSierra.com • Changing shocks after rear blocks : Suspension
www.silveradosierra.com/suspension/changing-shocks-after-rear-blocks-t56785.html
  1. Cached
  2. Similar
Mar 22, 2013 - 5 posts Will the factory shocks still have enough travel or will they max out? I also did the ReadyLift 2.5 leveling kit. Same question. Do I need to replace ...
5 Things You Should Know About Car Lift Kits ' eBay
www.ebay.com/gds/5-Things-You-Should-Know-About-Car-Lift-Kits-/.../g.html
  1. Cached
  2. Similar
When drivers install car lift kits, their goal is generally to take their vehicle from its ... lift kit or a suspension lift kit will come down to the type of tire they want to install on ... when installing a car lift kit is to purchase the wheels after buying the kit.
2" Leveling Kit, which one to buy? Do I need new shocks too ...
www.dieseltruckresource.com/.../2-leveling-kit-one-buy-do-i-need-new-shocks-too-1...
  1. Cached
  2. Similar
May 2, 2007 - After what I went through to install the leveling kit on my truck $250 ... I, personally, did kept the stock shocks on my truck and it seemed to do ...
Do I really need shocks with leveling kit? - Ford Truck ...
www.ford-trucks.com > ... > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
  1. Cached
  2. Similar
May 4, 2011 - 15 posts - ‎7 authors If you're still running factory shocks, it's worth changing them out even if you don't do the leveling kit. The truck will need to be aligned after a leveling kit. .... eye as the stock. install your lift and have the alignment checked. if it ... Do you need new shocks with rear lift blocks? 11 posts 6 Oct 2012 How much lift before longer shocks are required? 12 posts 15 Apr 2010 More results from www.ford-trucks.com
Your Lift Kit How to Guide on Lift Kits for Coilers & Independent ...
www.4wheelparts.com/buyers-guide-reviews/lift-kit-how-to-lift-kits-coilers.aspx
  1. Cached
  2. Similar
The following parts do not qualify for Free Shipping: ..... The downside to all coil spring suspension lift kits is that they alter the operating angles of ... That changes the axle location (axle moves to the rear in front, and forward in the rear), ... manners and efficient operation you will need to go with a long arm suspension lift. Do need to change rear shocks after lift kit Google Search
Jan 25, 2017 | Cars & Trucks
I cannot get the galaxy ace to automaticaly connect to my car hands frre kit ( Parrot )
The parrot car kit varies, there are about 10 different types of the parrot car kit and the connections varies slightly. Just follow these steps to connect ur galaxy phone to the car kit.
For this model of the parrot car kit,after the installation on your car,ensure the car is on
Parrot CK3000:
1. Start the car and ensure the car kit is on.
2. Activate Bluetooth on your phone, and search for Bluetooth devices.
3. Select "Parrot CK" from the list.
4. Enter 1234 on your phone when prompted for a password or code.
5. The Parrot CK3000 will sound a beep when connected to your phone.
Your phone has now been paired with the Car Kit and is ready for use.
For other models of the parrot car kit,repeat step 1 & 2 above and for step 3, u select the model name like "parrot EVOL" for the CK3000 Evolution model.
Aug 30, 2011 | Samsung Cell Phones
Where can i buy the wiring harness and dash kit to fit my kenwood KDC 2025?
This is a DIN sized unit and will fit nearly any kit. You need the kit/ harness based on the car you have. Just search your car year, make, and model then "radio dash kit". do the same for the harness. note that some cars do not need a kit as the factory radio is the same size as this radio.
May 09, 2011 | Kenwood Car Audio & Video
My iphone 4 will not connect to the ck-20w handsfree kit
I had the same problem. The solution was to reset the settings on the car kit. Switch engine off ensure no light on car kit control dial. Now push main dial in and hold for 10 seconds. Blue light will appear in car kit control dial. Now try and connect your iPhone. It worked for me, however callers do hear a bad echo when they talk to me. Hope this helps.
Feb 28, 2011 | Nokia Ck 20w Multimedia Handsfree...
Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Jun 23, 2010 | LG VX8300 Cellular Phone
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Cookie reboots when i connect to my parrot car kit
Your phone is probably not compatible with the car kit... try updating the phone firmware or check with the car kit support...
Jun 21, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Where can i buy a kit for s15l7 and how much its cost
Well what kind of kit are you looking for. A sub, amp, wiring kit all together, or a recone kit? cuz a whole kit I would go to ebay or to hifisoundconnection.com
Jun 13, 2009 | Kicker S15L7 Car Subwoofer
Cant connect my iphone to nokia ck-7w
not compatable, the nokia kit has very old software and will not work with Iphone, look at Parrot MKI car kits made for Iphone, very good.
Jan 16, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Volvo dealer installed ipod kit; will not play ipod
the radio is getting confuse ,remove the negative terminal for about 5 minutes and most likely it will solve the problem
Dec 20, 2008 | Scosche Industries Instl Kit 99+ Volvo S80
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
