Question about Dell Latitude D800 Notebook
MICROPHONE PROBLEM Hello: when i bought my computer as a second hand, there was only one C partition. Then I decided to add another two partition and format the drive . after installing new Window, I am having problem with sound system. I CAN HEAR THE INCOMING SOUND, BUT OUTGOING VOICE SYSTEM HAS PROBLEM. I APPRECIATE IF THE SOLUTION TO THIS PROBLEM IS EMAILED TO ME. THANKS
  • Anonymous Oct 20, 2008
    Manne
  • 426 Answers
Your problem from what i can gather is that the sound is crackling?... what your gonna want to do i 2 things 1sy try headphones,if the sound is still bad go to the windows mixer and turn down the levels of the "wave" and the "volume control" to about 75% and this should solve your problems
Posted on Jun 05, 2008
I bought an iphone 5s second hand but i cant unlock iphone icloud.what do I do to remove icloud account and password
you have to master reset and or factory reset or you can add new I cloud and use
Jun 06, 2017 | Cell Phones
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 28, 2010 | Iomega 500GB eGo BlackBelt Portable 34621...
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
First of, let me give thanks before hand to any one that can help me. I am somewhat of a geek so, i have tried a few things to fix my computer but nothing is working. It all began with boxes showing up...
Yes, your recovery discs will re-partition your hard drive. As long as they were created from your computer or bought from HP direct. This will however lose any software and files you have put on the system since you bought it. Beware!! :)
Aug 07, 2009 | HP Pavilion a6600f Desktop PC
Second-hand computer needing web-cam installation cd, is it legal
Hello.
Welcome To Fixya's Community.
Don't be afraid you won't have any legal problems.
Please Download Your driver through this link:
Logitech Quickcam Connect Driver.*
Thank You for Using Fixya.
Good luck.
*Choose Your Operating System to proceed to download in (the download page).
Apr 28, 2009 | Logitech QuickCam Connect Webcam
Partition problem
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
Jan 20, 2009 | Microsoft Windows XP Professional
C: Drive space issue
Hello
if you have to little space on your C partition you can resize it, if you using vista.
1. right click on my computer->manage
2. choose storage->disk management
3. right click on the C volume and extend volume
4. put more space on C and then OK. that should solv your problem
you can also move your swap file to D: that gonna save some space on C.
1. rightclick on computer ->properties
2. click advanced system settings
3. click on the advanced tab settings on performance.
4. choose advanced tab->change
5. click on D: and write a custom size(it should be double of your amount of ram)
6. click set
7. then click C in same window and choose "no paging file"
8. click set and ok, then restart your computer.
good luck dont forget to vote.
Sep 08, 2008 | Acer Aspire 3680 Laptop
Labtec verse 504
If you are using skype, go to the upper left hand top and click on call. Then click on audio settings and make sure your microphone is listed as the mike to use in the window of the drop down menu. It should say logitech something in the window that says microphone.
Jan 21, 2008 | Labtec Microphone Microphone
Dell Latitude D800 Notebook Logo
114 people viewed this question
Alun Cox
