Question about HP OfficeJet 4255 All-In-One InkJet Printer
Carridge error the printer shows Carridge Error when i print. i can't find any information from the product documetation.
  • Anonymous Jun 18, 2008
    same with me
  • 25 Answers
It’s a carriage jam, the carriage is plastic or metal that hold the cartridges and move from side to side to print ,try to move the carriage and see if it’s stuck or not
Posted on Jul 08, 2008
I had a paper jam I removed the paper but the error message is still there 86:01 is the code I have an HP Designjet T610 44"
86 errors are usually generated when the carridge assembly cannot move all the way from left to right. Open the top door and check on both ends to ensure that a small piece of paper is not jammed there. It does not take much to cause this error. Also make sure that the print head retainer is seated properly as I have had that issue generate this error.
May 11, 2011 | HP Designjet T610 InkJet Printer
How to fixe error(0990) in Richo gx3050sfn
Error 990 is an error that has to do with the ink carridge system. This is a Ricoh defect. If your printer is still under warranty you can call Ricoh and inform them of the error and they should replace it. To try and fix is 50/50. We usually just recommend getting a replacement.
Jan 19, 2010 | Ricoh GX3050sfn InkJet Printer
Requests new cyan toner...error light flashes 1 sec intervals
the toner carridge is stightly out of rotation, if you manually turn the carridge 2 notches this will reset itself when you close the cover.
si
Jun 24, 2009 | Konica Minolta magicolor 2400 Laser...
Hp 3310 error 0xc18a0201
if you are a tech and have opened one of these before, clean the service station on the right side, oil the carrage rod. time about 1.0 to 1.5 hours. most of the time this is the problem on inkjets.
Feb 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My Cannon Mx850 Printer has an error code of 6A00 what should I do?
I had the same problem after a paper jam. I removed all the paper and still had a same error. I read around the internet and ran into other Canon printers with similar problems. The error is caused by the print clean mechanism getting stuck. The suggested solution for other Canon printers also worked allowing me to fix my printer. First thing I did was turn off my printer. Second is to open the top cover allowing me access to the print cartridge area. With the power off, you can pull the printer cartridge carridge from the right of the printer to the left. Once you do that, look into the area in the right where the print carridge was and you will see two sponges in the bottom of the printer. Behind them to the left is a little mechanism that moves over the to clean them, I gently gave it a pull and it moved a little forward. I closed the printer and turned it back on. Error went away and it's working fine again.
Hope this helps!
Dec 18, 2008 | Canon PIXMA MX850 Multifunction Printer
Printhead errors
sounds like a carridge issue , check that the carridge can move freely and theres nothing stopping it
Oct 27, 2008 | HP Designjet 110plus nr InkJet Printer
ERROR MESSAGE : 0502
Hi gtiedith, sometimes the carridge just gets stuck. Leave the lid open. Power off the printer. Clean the carridge metal rod with a tissue. (Just a little wipe should do it. Than grab the carridge & slide it to the right about 2 inches. Close the lid & power on the printer. It should be just fine. Print a test page if you want to.
Have a good day!
Mike
Apr 02, 2008 | Office Equipment & Supplies
Printer carridge
Turn the printer off. Then move the print head back to the center with your hand and turn the printer back on.
Feb 16, 2008 | Dell Photo 964 All-In-One InkJet Printer
HP OfficeJet 4255 All-In-One InkJet Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
