Question about Asko D3122XLSS Stainless Steel Dishwasher
ASKO dishwasher D3122 drain pump wont stop pumping and the machine wont respond when we press any of the program or start/stop buttons. the program light is flashing. We can turn the power off with the main switch on top of the door but when turning it back on the pump starts pumping again. please tell me how to fix this problem so we can get it up and running again.
    New Friend:
Had the same symptom; pump wouldn’t turn off, program light flashing and would stay on even if turned off, only killing the mains power would turn it off. Ended being a small split in drain hose right next to elbow under the unit.
This thread saved us from buying a new one as my wife was about to do...so thank you.
Posted on Jan 05, 2019
SOURCE:
joe_lishman
  • 192 Answers
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Posted on Mar 26, 2010
Timon90
  • 126 Answers
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Posted on Jan 24, 2008
cschichtl
  • 43 Answers
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Posted on Sep 14, 2008
  • 28 Answers
SOURCE: ASKO D3122 PUMP STAYS ON AND MACHINE WILL NOT SWITCH ON
The machine has activated a safty seq. There is most likely water on the lower buttom. Leakage or drain pipe blocked. The power will get to the drain pump, when this happends. To prevent overflow on your kitchen floor. Dry out the water. Then it will start as usual.
Posted on Jul 27, 2009
SOURCE: Asko 3120 dishwasher drain pump
this is because ther is a leak from the main tank. Water goes under the main tank, where all electric motors, pipes an pump are. There is sensor in that area that trigger the drain pump. Up to 4 or 5 liters can accumulate in that area.
Only solution is to remove that water by tilting the washer on what ever corner.
Posted on Dec 05, 2009
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Hi, my D3120 Asko dishwasher starts but stops after about a minute. If I press the start button again, it starts but stops again. What's wrong?
When it shuts off, is there still water standing in it? First, you need to know if it stops because the pump (that pumps OUT the water) is working. When it stops, do you hear the water draining? ...(through your sink drain). Many times the tube that pumps out the water is clogged from food matter stuck in the drain tube. If you had a disposal put in recently, there is a plug that has to come OUT of the disposal to hook up the dishwasher drain.
Jan 02, 2015 | Dishwashers
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
D 3100 continues to pump out. Program stops and program button flashes
We have just fixed our Asko 3100 dishwasher. You need to undo the screws attaching the unit to the side cabinets. Pull dishwasher out and tilt forward to drain. Put towels down as lots of water. Machine seems ok now and running on a cycle.
Nov 06, 2010 | Asko Dishwashers
Jul 25, 2009 | Asko D3122XLSS Stainless Steel Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Oct 08, 2008 | Asko Dishwashers
Dishwashers Logo
1,859 people viewed this question
Top Asko Dishwashers Experts
Jose Pino
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
