Question about Intel Motherboard
Problem with motherboard MSI P35 Neo2-FR
I want to buy MSI P35 Neo2-FR. It has 8-pin power connector to provide power to CPU. But my power supply supports only 4-pin power connector. Will motherboard work if I join them together?
My processor - Intel Pentium Dual-Core E2160.
  • googlyone Jan 19, 2009
    i understand the 4pin on my old psu worked fine for ages but then i got a new psu and with in 2 days useing al 8 pis my pc stoped working, could this be becose i used all 8 pins and not 4? had 24 pin in bothtimes, could the cpu be damaged?
I just bought a msi p7n sli platinum. my board is better than yours hahaha, j/k, all playing aside, I have the same problem with the 8pin power connection. A power supply rated v2.2 has the proper 8 pin connection, but 2.1 or lower doesn't, regardless, plugging in two 4 atx pin connectors wont work because you'll be taking 4pins away from the main 24 pin plug (even though my manual says 20 pins will work, it doesnt, they lied!!!). However, when I put the normal configuration of 24 then the 4 in place of the 8, it works fine. The only thing i would worry about is overclocking, thats when you need to be careful with your voltages, etc. Also, I read somewhere that the 8 pin is actually 2 four pins, each 4 pin is for each side of the cpu...
Posted on Aug 13, 2008
  • 114 Answers
Suggest not, if you really wan try, go ahead, but i suggest not.
Posted on Jun 05, 2008
Msi p35 neo2 supports boot from pci express with revodrive 24ogb ssd?
Hello here is the home page:
http://www.msi.com/product/mb/P35-Neo2.html#/?div=BIOS
Why not connect to the sata drive ports ??
I have not heard about booting from pci express.
Pci express is a screen card slot.
Jul 07, 2013 | Computers & Internet
I was wondering if my pentium dual core E5700 would work in a msi p35 neo2??
It should work just fine - The Pentium E5700 is an LGA775 and so is the MSI P35 Neo2.
However, installing a processor into a motherboard is a bit more complicated than simply plugging it in, so I would consider having a professional install it for you.
Sep 16, 2011 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
I want a copy of 915g Neo2-FR manual
You can download manual on this page:
http://www.msi.com/product/mb/915G-Neo2-FR--V1-0B-.html#/?div=Manual
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 09, 2011 | MSI 915G Combo-FR Motherboard
Hangs on testing base n extended memory
appears to be a RAM/Memory Problem.
Or Corrupt Bios.
Try swapping The Memory to different Slots, or try 1 stick in Individual Memory Slots. Also Ensure the Board Has the Correct Ram Installed i.e DDR/DDR 2 et,c.
Mike @ Compurepair.
Nov 06, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Msi P35 Platinum motherboard bios problem with the latest bios 1.10. I want to put an oldest version, the 1.9 but i don't find a solution...
Flash the new bios and replace with the old one. The same thing you do when you update the bios of your motherboard.
Oct 27, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Hello please help i wanted to update bios for motherboard MSI P35 NEO2 and i didnt made a backup on a flopy disk (atleast i think this is the problem). Now after the computer restarted i get the message: I...
It seems to me that if your BIOS are not damaged, you can still make the copy and proceed as per procedure. Thank you for your consideration and choice for our service! My name is Constantin (arzconst is my internal nickname under Fixya.com).
Jun 19, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Pin assignments
Follow the manuals instructions, the cables should match or be similar to the manual. There's no problem with guessing in these situations if the cables and pins don't match go nuts you won't damage a thing.
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=591
Dec 29, 2008 | MSI 865PE Neo2-V Motherboard
Mother board
I reviewed the spec of your mother board and only thing i would look at is see if there is a BIOS update you can install. this would most likely fix it.
Translated:
Revis? las especificaciones de la placa madre y lo ?nico que ver?a es ver si hay una actualizaci?n de la BIOS que pueda instalar. esto lo m?s probable es que lo arregle.
Nov 02, 2017 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
P35 Neo2 Motherboard Jumpers
a quad Q6600 is manufactured @ .273 overclocked from the factory. at no time should this cpu ever be overclocked anymore unlessd you are using a watercooling system that keeps the cpu @ 69 degrees for stability. anything else will burn it out. lala linda
May 31, 2008 | Intel Motherboard
Intel Motherboard Logo
130 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
