Question about Admiral AW22 Top Load Washer
Admiral heavy duty washer - cleaning filter
Where is the filter? Could someone please give me a diagram of where i can find it so i can clean it out.
  • Anonymous Aug 24, 2008
    how to release front clo\ips
  • 116 Answers
Aw22 doesn't have one, remove the front panel to gain access to the pump, To do this insery a flat knife between the top panel and the front panel 4" in from each side to release the clips.
Unclip the two hoses to the pump after draining the machine, lower the external waste hose to floor level to drain.
tilt the machine back to remove the belt.
Remove the 3 bolts for the pump to remove and clean out.
refit in reverse order.
Posted on Jun 18, 2008
Admiral washer atw4470tq0 lint issues on clothes
clean the lint filter in the machine
remove any tissues and papers from pockets before washing
Nov 07, 2017 | Admiral Washing Machines
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Does the top loader heavy duty machine have a filter and does it need to be cleaned regularly. If so, where is it located?
No filter to be cleaned in the machine. There are however small wire mesh filters in the screw on connectors that connects the water hoses to the machine at either the tap side or where it are connected to the machine inlets. Unscrew the hoses from the tap and machine inlets and check both hose ends if the wire filters are not to clog up over time resulting in slow water filling of the machine. Remove carefully and clean with a nylon brush. Replace again.
Aug 01, 2014 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
Admiral heavy duty AK40 doesn't take hot watter
(the following is pre-typed but it's worth checking both hot AND cold filters!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 22, 2011 | Admiral Washing Machines
Front loader machine / heavy duty wash cycle does not work. It will start then something like a flashing F (something) appears
A few basic checks to do before calling someone out to look at it....
Is the water pressure turned on to maximum?
have you thoroughly cleaned the pump retun and filter baskets?
have you cleaned the rotating wash heads?
Try this and give the machine another go....
Dec 17, 2010 | Kenmore Dishwashers
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Mar 14, 2009 | Amana Washing Machines
My Admiral AU40001 keep giving fluffy stuffs
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Uh Oh, better call factory service before you have real problems!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in before you sign out!
Aug 21, 2008 | Admiral AW22 Top Load Washer
Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Dec 22, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
379 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
