Question about Candy CPCA270FFK Bottom Freezer Refrigerator
INSIDE LIGHT I have replaced the bulb inside the fridge, but it still doesn't light. Neither of the green lights at the front of the door have lit..not even the yellow warning light. The unit seems to be operating normally otherwise, although I may be imagining that the motor is running more than usual? Hope you may be able to advise a solution. Thank you, GED
    Scholar:
  • 111 Answers
I'd say the door switch is bad. Jiggle it. Spray some WD40 into it. But ultimately, remove it and test it for continuity. If there is no continuity in the door-open position, replace it.
But be careful. Some refrigerators have a second door switch with opposite function. It turns the fan OFF when the door is opened.
Posted on Jun 16, 2008
Its probably the control board thats blown when the bulb blew. Ive seen this before with this fridge.
Posted on Jul 10, 2008
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
Liebherr bulb switch
Generally at the top on the door inside the fridge there will be a little door switch as we call it. When pushed in it should open the contacts in the switch and kill the power to the bulb. If the bulb is not turning off when the switch is pressed then I would presume the contacts have been fused shut and if you would like the light to turn off you may want to replace the switch, or pull out the light bulb andhave no light. Good luck
Sep 08, 2012 | Refrigerators
Kenmore sidexside light burned out. replaced bulb, won't light.
There is a plastic switch that works the light in the door jam. Unplugg the fridge before popping this plastic switch out. I would order one first but if your light fixture is in good shape and not burn on the inside and the wires look good it is most likely the door switch. The door switch is just like an on off switch for any light its just spring loaded to turn on when the door opens. good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
There is no light inside fridge but working. what to do?
May be the bulb which provides light inside the fridge is fused. Locate the light and replace the bulb.
Dec 20, 2009 | Frigidaire FRT21H8 Top Freezer...
Fridge light does not work nor the display inside fridge is the bulb fused so when blown display goes out
Yes , the bulb lights up a fiber optic strand , which runs to the display . No light , no lighted display .
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light inside does not work, even after putting in a new bulb. Could it be a bad door switch. If so, can I replace it. How do I replace it?
It probably is a bad switch, in most firdge the switch is installe in a pop-lock construction. maybe the spring inside the switch is busted. Also please check the bulb you bought. it should be rated for refrigerators or else it wont work.
May 08, 2009 | Refrigerators
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Jul 04, 2008 | Smeg FAB28
Frigidaire PLHS267ZA Side by Side
Did you leave the door open? check the light socket for shorts ..check the door switch the light will go off when to door is closed..
May 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Replacing light bulb on dryer
Light is located just above the door on the inside of the drum. It has a clear plastic lens on it. The lens has a hinge on the top and a retention feature on the bottom. You can see all of this with a mirror. Simply push the button up and the lens will swing up. You can then access the light bulb.
Oct 27, 2007 | Dryers
Candy CPCA270FFK Bottom Freezer Refrigerator Logo
175 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
