Question about HP Officejet 4355 All-In-One InkJet Printer
HP 4355 I finally get a nessage saying - ERROR 2- THE SYSTEM CANNOT FIND THE SPECIFIED FILE (PRINT SPOOLER) Where would I be able to find the Print Spooler file? And can I upload ? would it work?
  • Anonymous Jun 12, 2008
    i encountered the printer spool problem in which message "error 2 is displaying that coudnt start the file specified
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
First we need to know which operating system you are using.
If you are using XP. Then follow the below steps to refresh the spooler.
Click start-->run-->type services.msc-->locate print spooler in the services window and right click on it and click stop and then click start else simply click restart or refresh and then try to print.
If you are using Vista, then perform the below steps.
  1. Click Windows (HP 4355 - c01330063.jpg ), right-click Computer , and then click Manage . The Computer Management window displays.
  2. Double-click Services and Applications , and then click Services .
  3. Double-click Services .
  4. In the right pane, right-click Print Spooler , and then click Properties .
  5. On the General tab, in the Service status section, click Stop and then click Start .
Posted on Jun 05, 2008
Unable to print and make photocopies
when you try to print does it come up with any error message?
or does it get sent to the print spooler and then lost in cyberspace?
or does it get to the printer and then the printer says no?
for the error message follow what it says so if the error is no connection check that the wires are attached. if it comes up with an error code look it up on the HP website.
if it gets lost in cyberspace try reinstalling the printer with an updated driver.
and finally if it says no go to run and type services.msc and scroll down the list till you see print spooler if it says it is stopped start it and try again, if it still doesn't work try updating the firmware
Jan 03, 2014 | HP LASERJET PRO M1132 MFP
Print spooler error 2
First you must check that the "spoolsv.exe" file IS in the C:\windows\system32 folder! Start there, and if that does not solve it then keep searching. Theres a whole lot of info out there regarding how to solve a spooler error 2!
Jul 07, 2009 | HP Photosmart 3310 Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
HP print spooler problem and error 1068. Want my printer back!!!
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
I recently removed my lexmark printer from my computer, to use a HP system. My print spooler will not start, and the LexBce server will not start either. I don't have a printer hooked up to my dell. Is...
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
and try this also,
  1. At the command prompt type lexbces -u and press ENTER. You will receive confirmation that the file has been removed and that you have to delete one other lexbces.exe file manually.
  2. Use the Search option to find the lexbces.exe file and then delete it from C:\Windows\System32
Sep 25, 2008 | Computers & Internet
Spooler servis dont work
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Aug 25, 2008 | HP Office Equipment & Supplies
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
66 people viewed this question
Ben Johnson
