Question about Asrock K7VT4A-Pro Motherboard
1 TB HD of Samsng is not recognized
Hi
I bought a Samsung HDD 1 TB 32MB SATA II.
This was not recognized by BIOS. I tried the 2 different jumpersettings of the HDD (no succes), checked the cables (works), and checked the HDD. The HDD probably is OK cause it is recognized when I use the HDD as external.
How do I solve this?
Http://www.asrock.com/mb/download.asp?Model=K7VT4A%20PRO download the sata drivers for k7vt4a pro,include that drivers on a xp cd instal win. and it will work...
Posted on Dec 19, 2008
I believe you have to reinstall Windows and use the SATA diskette that you can download from the ASrock website. The diskette basically tells windows you are going to use a SATA hard drive instead of an IDE drive. I know you have to enable the RAID setting in the BIOS. Here is a copy and paste from the manual:
If you want to install Windows 2000 or Windows XP on your SATA HDDs, you will need to make an SATA driver diskette before you start the OS installation.
STEP 1: Insert the ASRock Support CD into your optical drive to boot your system.
(Do NOT insert any floppy diskette into the floppy drive at this moment!)
STEP 2: During POST at the beginning of system boot-up, press <F11> key, and then a window for boot devices selection appears. Please select CDROM
as the boot device.
STEP 3: When you see the message on the screen, “Do you want to generate
Serial ATA driver diskette [YN]?”, press <Y>.
STEP 4: Then you will see these messages,
Please insert a diskette into the floppy drive.
WARNING! Formatting the floppy diskette will
lose ALL data in it!
Start to format and copy files [YN]?
Please insert a floppy diskette into the floppy drive, and press <Y>.
STEP 5: The system will start to format the floppy diskette and copy SATA drivers into the floppy diskette.
Once you have the SATA driver diskette ready, you may start to install Windows 2000 /Windows XP on your system directly without setting the RAID configuration on your system, or you may start to use “VT8237 SATA RAID BIOS” to set RAID 0 / RAID 1 / JBOD
configuration before you install the OS. Before you start to configure the RAID function, you need to check the installation guide in the Support CD for proper configuration. Please refer to the document in the Support CD, “Guide to SATA Hard Disks Installation and RAID Configuration”, which is located in the folder at the following path:
.. \ SATA RAID BIOS
You may also set the RAID configuration by using “VIA RAID Tool” in Windows environment.
Please refer to the document in the Support CD, “Guide to VIA RAID Tool”, which is located
.. \ VIA RAID Tool
Posted on Jul 22, 2008
  • 114 Answers
Some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Posted on Jun 05, 2008
  • Burns Milheron
    Burns Milheron Jun 05, 2008
    sorry, my stupid laptop has a sensitive touch pad, anyway, I suggest you get a smaller HD that is comaptiable with your PC, or get a new Motherboard & Processor
CAN'T GET TO DRIVE
internal sata.
ok, here are the simple steps.
1: it must have power to the power cable, try 2,
2: put ear to HDD case is it spinning inside.
no, hdd is bad.
yes, good. no clicking or clanking allow, from arms distance.
3: boot pC, does BIOS see the drive (data cable connected)
yes/no
if no, try all SATA ports. some are only for RAID, try them ALL!
if BIOS cant see a real Sata drive, the drive is dead.
let me explain BIOS, this only proves 2 things.
1: power makes it to the HDD digital chips/
2: and those chips can PNP report the drives spec and ID.
it does not prove the drive works, only that it can talk.
see?
3: if you get it up in BIOS, (this is all par for the A+ classes today)
3a; the boot wINDoZ , run disk manager.
if DM sees the drive, then its there,. good.
now set the drive letter, if missing.
now program manager can see the drive.
give the drive volume label, like: 2TB-monster...
if you can not lable the drive, its VERY VERY sick.
as always , first walk then run.
Oct 01, 2013 | Western Digital WD Caviar Green WD20EARS -...
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Hi dear Expert. I Have my MB ASUS M2A-VM HDMI. SATA1(0) was connected with HDD Samsung 320Gb. SATA2(1) was connected with CD drive. Other ports spare. Now by commecting new HD Samsung 1Tb on SATA3(2)...
If the new Drive is setup on a different channel than the First HDD and CD then it should be set to Master. In the Bios you probably need to activate the second SATA channel so the Auto Detect Function can work. You also need to check that the MB can support a drive that size. Not all MB will support an HDD of that size. Aside from the Obvious of checking all your cable connection to insure that they are all solid the only other thing I would recommend is that you switch the CD and new HDD positions. Put both HD's on the same SATA channel and the CD on the Separate channel. This would require making 1 HD a Master and the other a Slave and changing the CD to a Master since it will have it's own Channel. Second, try remove all but the New HDD from the system. Set the New HDD up as the only HDD and see if the BIOS will see and allow you to select it. If it will not there is a problem either with the size of the HD or with the HD itself.
Sep 23, 2010 | ASUS M2A-VM (0610839149438) Motherboard
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
Asrock K7VT4A-Pro Motherboard Logo
1,042 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
