Lapttop Touchpad and Keypad freeze.
Hi
I've had a laptop for a year now. It's a Sony Vaio VGN-C2S runnin on Vista. It all seemed fine till one day the mouse and keyboard stopped working on every startup, i tried unpluggin the battery to restart it and tried again but the same problem. I have tried taking the battery out and leaving the main power suplly in, yet still the same problem happens. Is there anything wrong that you can point me to, all help is appreciated.
Thanks
  • 1 more comment
  • DJKash Jun 08, 2008
    ivee tried changing the keyboard and mosue but its still the same, the keyboard works since it the caps locks light flashses when pressed but becomes irresponsive when it gets to loading the desktop.
  • AnandX Jul 07, 2008
    i have acer 5050 laptop, from last week my keyboard and touch pad stopped working in normal XP mode, but it is working in safe mode. I tried re installation of XP professional. if any one can help me. my external mouse is working.
  • delany1224 Dec 19, 2008
    new acer, touch pad inop
    any help
    downloaded a driver, and restarted pc, still inop
Hi DJ try to check your cables and connections, if it still the same, try change your keyboard and mouse,borrow from others to double check other device that works with other's PC and try your keyboard and mouse too on other PC. have you identify the problems?
Try also to go CMOS settings by pressing DEL or F2 when restarting your PC , go to device options and Enable options that supports USB or PS2, save it and restart your PC...
yo:)
Robert .. uncco@yahoo.com
Posted on Jun 05, 2008
Sony vaio laptop half screen black on the right
Sony Vaio is one of the most prominent brands of laptops on the market, and also one of the most expensive. The laptops, created by Sony, are known for their efficient processor functionality and sleek designs. While the Sony Vaio line of laptops are considered high-end, they are also prone to display problems.
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Dec 13, 2012 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
Problem with touchpad sony vaio vgn-ns295d my touchpad is only works when i touch it with two fingers, otherwise its not, and when i touch it with two fingers then i remove one and it works.. seems...
Thanks for asking Fixya !!!
Goto Start>>Run
Type
devmgmt.msc
press ok
in device manager doubel click Mice and pointing device and right click and uninstall the touch pad driver and uninstall
then restart the computer ..
Thanks
Feb 18, 2011 | Sony VAIO VGN-FZ240E/B Laptop
I upgraded my SONY VAIO VGN-C2S/H from vista to windows 7... but its not recognizing memory stick
Go on sony website and dowload the proper drivers for your machine. The old drivers from vista might not work properly in 7. I, personaly, recomand a fresh clean install in the upgrading cases. That means to format the HDD and install everything from zero. Upgrating from an OS to another by installing an update patch is not a big deal. There might remain some dirty registry wich will make the sistem running slowly.
Jan 25, 2011 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
Laptop Freezing Problem
To be honest this still sounds like a fan problem. The freeze will happen if the laptop overheats. Maybe you should have it repaired again by a different company.(ask for the fan to be replaced!)
Nov 01, 2009 | Sony VAIO VGN-N110G/W Notebook
I want to Down DRIVERS for Sony VAIO Version PCG-7L1M
Is it VGN-NR310E/S?
if so go to:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNNR310ES&LOC=3
All the drivers for XP as well as Vista Home Premium are there.
Hope this helps.
Bastian
Jun 02, 2009 | Sony VAIO VGN-NR310E/S Laptop
I want to install win xp on sony vgn-nr498e but i cant do it
you can,t b,coz the system is based on vista thats y u,ve to reboot with vista and can,t b installed xp pro ok-doky
Feb 09, 2009 | Sony VGN-NR498E/W 15.4" VAIO NR Series...
Sony vaio vgn-n250e laptop microphone problem
You can download what ever Vista driver required for your VGN-N250E Sony Vaio at Sony Vaio Support.
Good Luck.
Oct 24, 2008 | Sony VAIO VGN-N250E/B Notebook
Formating problem
hi i have sony vaio VGN-NR-220E i want to know how i can format this system there vista operating i want Windows xp
Aug 22, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Computers & Internet Logo
329 people viewed this question
David Payne
David Payne
