Question about Freezers
I can't figure out what model/size my frigidaire freezer is
I found a service data sheet that says Compact Chest Freezer and has the numbers 216372500.
I also found a tag on the side that has 5/99 (the year made maybe?) and the numbers MFC0(could be letter O)7M3FW1 and just below that one is
WB92204485.
I also saw something saying 5.0 amps and 115 volts.
The freezer is in a location where I cannot see the whole tag - I was able to get my phone down beside and took a picture of the stuff I did get - can you help me?
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
huuum
  • 750 Answers
SOURCE: Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 10, 2008
tborn6
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
Jul 20, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
Chest Freezer not freezing
check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Nov 14, 2009 | Freezers
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Nov 19, 2008 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Freezers Logo
315 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
