Question about Hitachi HTD-K170 System
AX-M140 problems, problems
My system seems to constantly have issues. It times out and won't allow you to replay a disk after a while without turning the device off (at the mains) and back on again. It doesn't like copying from disks very much, several attempts at doing that have failed, but the worst is that if you play back from the hard disk it hangs once it has played the last track.
Yep, I know I should have taken it back but this is our third hi-fi purchase, I really just want it to work properly. I suspected it needed a firmware update but have no idea how to get one. Hitachi site wholly unhelpful.
  • Anonymous Jul 25, 2008
    i have the same problems
    also every time i load a disk it spends about a minute trying to play it, then says theres "no disk"! if any one cam help it would reallly apprciated.
  • mikinik-men Nov 02, 2008
    Yep. I have the same, hangs up after the last track has been played. But it gets even worse. After getting the message "No Disc" the machine was returned to Currys, still under guarantee, and was returned after replacing the drive system. One month later in DVD mode, the "No Disc" comes back up, and guess what? Now out of guarantee!!! Looks like i have bought a pup.
    Mikinik
Open the dvd case ,6 screws.
remove the bar which holds the cd on to the spinning middle piece it is secured with two screws, the cds will rumble a little until playing but will work.
Posted on Feb 11, 2009
  • 1,512 Answers
Hi mate... yes we got cut off and I couldnt find you. Appears you have surfaced from the depths of the server. can carry on talking in here is you like. It is almost real time.
regards
Graeme
robotek
Posted on Jun 06, 2008
HITACHI AXM 140 SYSTEM
Try to reset the system.For reset procedure,click the link below :-----http://technoanswers.blogspot.com/2012/01/hitachi-ax-m140-system-display-keeps.html
---------This will help.Thanks.
Jan 27, 2012 | Audio Players & Recorders
I have been using Nero Express V 6.0 on my newest computer [operating system Windows 7] for over a year, and suddenly it won't allow me to burn DVDs. Is this a driver problem? ... and if so, how can...
When you try to burn, how many steps in Nero Express work correctly.
What happens when you try to burn?
What error-message(s) do you get?
Does it seem to burn a disk, but the resulting disk is "empty" or "never-written-to" ?
Jun 11, 2011 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Hp dv3 boot: no bios, blinking screen
You re having the problem with your hard drive because constantly putting Off your system without following the Shutdown Process will corupt your hard disk and probably crash out so you will have to reload the system by reformating the hard disk or probably change the hard disk and reload it all will be fine ok anything else post back CHEERS
Mar 01, 2010 | HP Pavilion dv3z Entertainment Notebook
When i turn on my pc i get the message "windows host process (rundll32) has stopped working.
Try a system restore if you can to before this occured
OTHERWISE
Please follow these instructions to check which software is causing this issue:
1. Click on Pearl (Start Button), in the serach box type:
msconfig
and hit the enter key on the keyboard. It should open the System Configuration Utility window.
2. Click on Services over the top and then at the bottom right corner, put a check in the "Hide all Microsoft services" checkbox.
3. Click on "Disable All" button.
4. Click on "Startup" tab, and then click on "Disable All" button again.
5. Press OK button and then "Restart" button on the following window. Let the computer restart.
6. Once you're back on the desktop, you'd get a window for System Configuration Utility. Put a check in the box "Don't Show....." and then press OK button.
7. Now, once again check the issue. If the issue is resolved, open System Configuration Windows again and then enable all the services from Services tab and then check the issue after restarting the computer in the same way as mentioned above.
8. If issue is still resolved, enable half of the Startup items from Startup tab and then check issue.
9. If issue occurs again, it means, there's a culprit in the checked startup items. But if issue doesn't occur, then issue could be with rest of the Startup items. Now, uncheck the first half startup items (that were check before), and then check rest of the half items. Check the issue again.......
10. Now, if the issue occurs, then make a note of all the names of the startup items and then follow the same procedure, for them. Now, you need to be careful, as by design the System Configuration will sort all the enable startup items to the top. So, it means all the entries would be mixed on next reboot. From now on you need to make a note of all the entries that you're enabling or disabling........
Aug 22, 2009 | Microsoft Windows Vista Home Basic Edition...
Dell XPS M140 laptop
The virus could have scrambled and or removed your Windows operating files on your hard disk.
If you can get into your BIOS and it still detect your hard disk, then I suggest your delete your hard disk partition, create a new one and install Windows again including all your device drivers (video, audio, network etc.) and latest Windows service pack and your programs.
Nov 29, 2008 | Computers & Internet
Humming from speakers
bad grounds wires usally will do this
Feb 10, 2008 | Audio Players & Recorders
Solving word problems involving linear equation
A positive number is 5 times another number.If 21 is added to both the numbers,then one of the new numbers becomes twice the other number.What are the numbers
Nov 29, 2007 | Computers & Internet
Hitachi Hi fi module ax-m140
Use a computer to rip your CD's Then copy them to a memory stick. Then you can plug the memory stick in and copy the files to the hard drive that way. Each files takes about 5-10 seconds. Hope that helps
Jun 18, 2007 | Hitachi HTD-K170 System
Hitachi HTD-K170 System Logo
603 people viewed this question
Top Hitachi Audio Players & Recorders Experts
Man Ana
Man Ana
Level 1 Expert
 Grubhead
Grubhead
Are you a Hitachi Audio Player and Recorder Expert? Answer questions, earn points and help others
