Question about Indesit 24 in. D63 Free-standing Dishwasher
Too hot Water not circulating during wash cycle. Machine will pump out and allows water in. Machine gets very hot if left on - does not switch off automatically. Programmer revolves freely.
  • 868 Answers
Replace bad control board
Posted on Jun 05, 2008
No hot water
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
  • Is the hot water turned on? If not, turn it on.
  • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
  • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
  • Sep 21, 2008 | Hotpoint VBXR1090D Top Load Washer
    Hotpoint Ultima WF860T
    Alarm
    code Description of fault User
    code Effect
    E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
    E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
    E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
    E22 Problems with water drain during drying or drying
    condenser blocked E20 Heating phase skipped 8.5
    E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
    with door closed 8.6
    E32 Incorrect calibration of analogic (electronic) pressure
    switch --- Cycle PAUSED 8.7
    E33
    Incongruency between level of analogic (electronic)
    pressure switch and level of anti-boiling pressure
    switch 1
    --- Cycle blocked
    with door closed 8.8
    E34 Incongruency between level of electronic pressure
    switch and level of anti-boiling pressure switch 2 --- Cycle blocked
    with door closed 8.9
    E35 Water level too high --- Cycle blocked with door
    closed and water drain 8.10
    E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
    with door closed 8.11
    E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
    E38 Pressure chamber blocked --- Heating phase skipped 8.12
    E41 Door open E40 Cycle PAUSED 8.13-14
    E42 Problems with door closure E40 Cycle PAUSED 8.15-16
    E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
    E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
    E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
    with door closed 8.19
    E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
    closed (after 5 attempts) 8.20
    E52 No signal from tachometric generator --- Cycle blocked with door
    closed (after 5 attempts) 8.21-22
    E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
    with door closed 8.23
    E54 Relays (motor) contacts faulty --- Cycle blocked with door
    closed (after 5 attempts) 8.23
    E61 Insufficient heating during washing --- Heating phase skipped 8.24
    E62 Overheating during washing --- Drain, end of cycle 8.25
    E63 Insufficient heating during drying Heating phase skipped 8.26
    E64 Overheating during drying --- Heating phase skipped 8.27
    E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
    E71 NTC wash sensor faulty --- Heating phase skipped 8.29
    E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
    E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
    E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
    (door open) 8.32
    E85 Circulation pump faulty --- Drain, end of cycle
    (door open) 8.33
    E91 Communications error between main PCB and user
    interface --- --- 8.34
    E93 Configuration error E90 Cycle blocked 8.34
    E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
    EF1 Drain filter blocked LED-EF0 --- 8.35
    EF2 Excessive detergent LED-EF0 --- 8.35
    Regards David Marsh
    Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
    I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
    It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
    If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
    Try following the diagrams at top of this website to get idea of parts.
    Oct 13, 2011 | Dishwashers
    The washing machine won't fill with water at all. we have cleaned the pump valve and we have checked the water lines. are there any other things that could be causing this problem?
    You will want to check and make sure the door handle/lock is switching on. the front load unit will not fill with water with the door open. Check that the latch is engaging.
    Oct 05, 2010 | GE WSXH208A Front Load Washer
    Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
    This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
    Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
    Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Cold water is not filling machine when place on cold washer cycle
    Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
    Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
    Machine keeps stopping and showing fo5
    ALARM CODES
    E33
    switch 1
    --- Cycle blocked
    (door open) 8.32
    (door open) 8.33
    Regards David Marsh
    Oct 22, 2009 | Washing Machines
    Hot water not going into washing machine
    hi there,
    try the following, it may help:
    * Is the hot water turned on? If not, turn it on.
    * Is the washer getting cold water but no hot water? If so, check to see if the control panel
    Nov 05, 2008 | Frigidaire Gallery GLWS1339EC Top Load...
    No water going to feed machine
    There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
    There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
    • Is the cold water turned on? If not, turn it on.
    • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
    • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
    There's no water at allIf there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
  • From Repairclinic
    Oct 12, 2008 | Dishwashers
    Indesit 24 in. D63 Free-standing Dishwasher Logo
    95 people viewed this question
    Top Indesit Dishwashers Experts
    noel
    noel
    Ted Maxwell
    Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
