Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Sony camcorder model dcr-pc105e
When turned on the display shows ' memory stick error'
I have been putting up with the same problem for 6 months. I finally had had enough and ripped the camera to pieces. It turns out there is a design fault in all the cameras with electronics in the loading door. You see, to enable the device in the door to function, there needs to be wires feeding it. Those wires get "metal fatigue" after so many openings and closings and break off. So, when it happens, you need to learn to live without it, or bin it. Cheers.
Posted on Sep 29, 2008
Why do I see MEMORY STICK ERROR on my Sony camcorder?
Check the memory stick for a little slide lock on the side. Make sure that is not in the locked position. This feature is there to prevent people from recording over special memories, like weddings. But sometimes during handling (or just not knowing) people accidentally switch it to "lock"
Good luck
Oct 03, 2012 | Sony Handycam DCR-TRV350 Digital Camcorder
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
Memory stick recording
that means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
CHARCOIS
Sep 18, 2008 | Sony Handycam DCR-PC105E Mini DV Digital...
Memory Stick Error
Go to camera menu and Format memory stick then try.
Sep 06, 2008 | Sony Handycam DCR-TRV340 Digital Camcorder
Won't take photos
Have you checked all settings are correct for this, and the correct memory is inserted ?
Aug 05, 2017 | Sony Handycam DCR-PC105E Mini DV Digital...
Memory Stick Error, PLEASE HELP!!!
Does any other Sony memory stick still work in your camcorder? If yes, means memory stick isn't match with this camcorder. Use Sony memory stick.
Jun 09, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
Will Not take Photo's
Hi
I have a Sony Handycam video Hi8. The recorder is not focusing. When I look through the lense everything is blur.
Please advise.
Jul 22, 2007 | Sony Handycam DCR-PC105E Mini DV Digital...
CAN ANYONE HELP SOLVE THIS PROBLEM URGENTLY?
Unless somebody comes up quickly with a better solution for you, it may be an internal battery problem, especially if you keep having to set the time. For your local repairer click on this Sony support page. http://www.sony.co.uk/support/ShowExternalPageForProduct.action?supportProductModelName=DCR-PC105E&targetTab=externalLinkType_manual&site=odw_en_GB&page=ProductSupportDealerLocator§iontype=Support&externalUrl=http%3A%2F%2Fpdf.crse.com%2Fmanuals%2F3081627112.pdf&externalLinkType=manual
Dec 13, 2006 | Sony Handycam DCR-PC105E Mini DV Digital...
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
203 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
