Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint ultima 1200 Wm72 Erroe E14
I have an E14 error showing on the screen . Can you tell me what this error is please
Thanks
nigel
I think you will find that the error relates to the heating element.
E14 on the Hotpoint WM75E means that there is a problem with the water heating.
Posted on Jun 09, 2008
Looking for a door seal for a Hotpoint Ultima 1200.
If you have not yet got door seal, then go to www.hotpoint.co.uk.
Please rate my solution.
Thanks.
Jul 09, 2009 | Hotpoint Ultima WD72 Front Load...
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Thanks.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
No handbook
Try finding the handbook in here, if that is not available call them by phone.
Check also WM72 Quick Guide.
Jan 15, 2009 | Hotpoint Ultima WD72 Front Load...
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
ERROR MESSAGE ON SCREEN STATES CHECK OUTLET PIPE E15
It probably needs a new Pump, the wm72 has what they call a magnet pump and they can give false readings to the programme. Anew pump will cost sround 20 GBP. For an engineer to do it will cost around 50 GBP.
Nov 18, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint 1200 wm72
its your heater element that is faulty more than likely will need replacing m8
Aug 08, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
880 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
