Question about HP Officejet J5780 All-In-One InkJet Printer
HP J5780 All in one printer
When copying using the automatic paper feeder, the copies come out with a solid black line down one side of the page. When I put the page to be copied directly on to the glass and don't use the feeder, the copies come out fine. How can I cure this? Thank you.
  • Anonymous Mar 31, 2014
    Copies are all black. Printer works great when receiving doc from computer. Put paper on glass or feeder output is solid black
When i try to make a copy, it printing out just only whole page black color even ,I put color button.Why.
Posted on Nov 29, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Once try to make a scan and if we are getting line even while scanning. Then perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01129408&cc=us&lc=en&dlc=en&product=3301296
Directly go to step three and then try to make a copy.
If the issue still persists then power cycle the all-in-one.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Now try to make a copy and check for the result. If the issue still persists then reset the all-in-one.
  1. Unplug the power cord from the product.
  2. Press and hold # and 6 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
Posted on Jun 05, 2008
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
When i use the automatic data feeder, i get a line on my copies
Hi Donald,
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link:
host220 brother com In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Nov 15, 2013 | Brother Network-Ready All-In-One Laser...
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Lines of copies utilizing automatic feeder
look to the side of your big glass and you'll see a piece of glass about 1.5" wide. thats the galss that is used for scanning from the feeder. theres got to be something on that glass. possibly white-out or even a small speck of toner can cause that. look closely.
hth,
razors
Mar 16, 2009 | Brother MFC-9440CN Laser Printer
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Jul 01, 2008 | Canon ImageClass D861 Printer
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
848 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
