Question about Kodak EasyShare C310 Digital Camera
2 gb sd card
Trying to get my new memory card to work in my camera and it can't format it?
  • 1 more comment
  • michaela19 Jun 26, 2008
    i got a 2gb for my kodak c310 and i go to format it but it says on the screen "FILESYS ERROR e00100" after a minute or so the screen goes blank. and i have to restart it but still having no luck
  • Anonymous Jan 09, 2009
    my new sd card will not formate it saysmomory card is full then filesys error e00100
  • simmons904 May 22, 2009
    I have a Kodak C310 digital camera and I am trying to format a 4GB memory card into it, and I would just like to be able to format it. Can You give me a simple way to do this?
Hey Guys yes I am from South Africa Just bought the SD 2 GB ScanDisk sd card - Same Thing
Pathetic to say the least!
Anyways - Thanx for the comments what i have learned from this is that its not just ME with the problem, and I must say I feel better!
Kodak C310... well you cant compare it with the big boys...
Cheers
Stan
Ps: formatting the card in your pc does not fix the problem with the camera, I tried it.. The card works fine on my Garmin
Posted on Oct 25, 2008
From what I have read, this camera only supports up to 1GB cards.I too tried a 2GB card and got the same behavior. Finally got a 1GB card and it's been happy sailing since.
Posted on Sep 12, 2008
    President:
  • 1,944 Answers
Try formatting it in a card reader and your PC.
Posted on Jun 05, 2008
Bought a sony dsc h300 camera about 2 years ago...bought a Kingston Memory card for it....what do I do now ?
Have you tried formatting the new memory card? Sony suggest you format a new card using the camera.
Supported capacity:
  • Memory Stick Duo" media: up to 64 GB
  • "Memory Stick Micro" media: up to 16 GB
  • SD card: up to 64 GB
  • microSD memory card: up to 64 GB
You may also want to check the camera's user guide to narrow down what's causing the card not being detected.
http://docs.esupport.sony.com/dvimag/2014/DSCH300_guide/en/contents/12/01/04/04.html
Jul 08, 2017 | Sony Cameras
I have a Polaroid i1032 10.0 megapixel camera. the user guide says that i can use up to a 1 gb SD memory card. I've used a 2 gb SD card and it works fine. My question is can I use SDHC cards 2 gb, 4 gb, 8...
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Mar 22, 2011 | Polaroid i1032 Digital Camera
New sandisk 8 gb sd card reports memory error when inserted in camera. other cards work in camera. card is recognized by laptop. tried reformatting by Vista
There are no 8GB SD cards. Cards this size are SDHC (High Capacity). SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
Dec 01, 2010 | SanDisk Cameras
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
A 2gb memory card says memory full tried it in
No, that camera works with the 2gb cards just fine. You will want to try to format the card in your computer first, then try it in your camera (format it in the camera before using). If it doesn't format in the computer, it is a bad card.
Jul 19, 2009 | Kodak EasyShare C330 Digital Camera
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 22, 2009 | Kodak EasyShare C330 Digital Camera
Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Mar 22, 2009 | Kodak EasyShare C310 Digital Camera
New 2 GB Memory cards say cards full when installed
The SD card may have to be reformated. You should do this in the camera you want to use the SD card with. Do not format the card with your computer.
In you manual or on the menu of your camera there is a "Format" procedure. follow that and your camera will work again (REMEMBER) if you have images on the SD card down load them before you format the card.
Once you down load the images from your camera you should reformat the card to clear it in order to shoot more images.
Mar 20, 2009 | Kodak EasyShare C330 Digital Camera
New memory card and the camera says its full
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C310 Digital Camera Logo
625 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
