Question about Samsung SF-330 Plain Paper Inkjet Fax
Samsung SF3000 Fax Machine - Lines appearing accross the paper
Merci de me communiquer le manuel d'utilisation du fax samsung sf-330!
Posted on Jul 01, 2008
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
Black vertical lines on transmitted faxes.
Just go to menu and then in tools...run alignment and clean them....
Jun 29, 2010 | HP 1040 Plain Paper Inkjet Fax
When I am faxing do I put the paper print side up or down?
Most printers are different even from the same monufacturer. The easiest way to tell is look for the icon near the place where you load the fax. There is what appears to be a sheet of paper with a corner folded over. If the icon shows lines across the main part of the icon, and there are no lines on the part that is folded over, then the paper goes in the machine face up, or lines up. If there are no lines on the main part of the icon but there are lines on the part that is folded over, then it signifies the paper being loaded face down, or lines down.
Sep 12, 2009 | Canon L120 Fax Laser Printer
Fax machine is saying paper jam but does not appear to have paper jam
I have been having the same problem with my fax.
If you switch off the fax machine for 30min then switch it back on again the fax will resets its self and this should clear the error.
Martin
Jul 14, 2009 | Samsung Office Equipment & Supplies
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Jan 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Poor Print quality - black lines appear on page
If you see black lines on the drum, it is very likely that the drum unit is bad. Replace the drum unit and rest the drum counter. If you wait too long, you will cause toner build up in the fuser and will cost yourself several hundred dollars to get it replaced. More in labor than parts.
Use a soft cotton or very soft paper towel and wipe the excess toner from the drun. If there are lines worn in the surface of the drum, then replace it ASAP.
Nov 15, 2007 | Sharp FO 4450 Laser Fax
Samsung SF-330 Plain Paper Inkjet Fax Logo
112 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
