Question about Refrigerators
Trays at back of fridge filling up with water every couple of days
I have two trays located at the back of my fridge/freezer ( at the bottom ) and these keep filling up with water every few days. I have also noticed that drips of water frequently run down the back of the inside of the fridge section and I think this may be cause of the problem ? The fridge does however seem to be working efficiently otherwise and is always keeping the contents cool. I have it set to +4 degrees.
I have a Miele KF 7652 SN ed
  • norriekr Jun 16, 2008
    same issue, same fridge i think and looking for a fix
  • 1314 Answers
SOURCE: FRIGIDAIRE FRS20ZRGD7 (SIDE BY SIDE) WARM FRIDGE/ COLD FREEZER HELP!
look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost system1.gif too if i can be of help or you need to know something just reply to this post
Posted on Mar 30, 2008
  • 1314 Answers
SOURCE: Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Posted on Apr 04, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
woodchuck789
  • 4070 Answers
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 30, 2009
Testimonial: "thanks, all fixed!!"
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
Water doesn't fill the ice maker trays
Most ice makers need to be at 8 to 13 degrees to make ice. If you had to defrost coil, then it's a defrost issue. Could be timer, bi-metal our heater.
Aug 17, 2012 | Refrigerators
Water collects in the tray below the produce trays
you may have a block in the drain so instead of the water running through the back hose its runing down to the bottom of the fridge look for the little hole inside the fridge it will have runners at the back to guide the water
Apr 20, 2010 | Sub-Zero Bottom Freezer Refrigerator
Refridge leaking water inside it...
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
May 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Should be a little drain hole in the bottom rear of the fridge. Use a pipe cleaner or somthing similar cos it,s probably blocked. Quite a common problem.
May 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Freezer leaking water
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Feb 18, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
Inside freezer is icy and water cant get in to make ice.
the water valve is probably bad. it leaks slowly into that tube and freezes up solid causing this problem.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Jul 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Moffat fridge leaks, every couple days water on floor at front of fridgee
The reason why it leaks is because the pipe that discards the water underneath the refrigerator is clogged and must be cleaned. The water normally drains through this pipe into the bottom tray of the refrigerator where this water deposit is supposed to evaporate during normal conditions. When the pipe is clogged then the water does not fall into this tray. Therefore, turn off the refrigerator (power off/ previous taking-out of all food of course!) than go behind the fridge and locate this pipe (plastic hose / if you have difficulty locate at least the tray on the bottom and than locate this pipe / to locate it you can see the little hole on the back bottom of the freezer this is where the water is supposed to get out. Put water into the hole and you can see where it falls). Clean the pipe and the problem should be solved.
Jul 09, 2008 | Refrigerators
Kenmore 795.755744
I have a trio 7755 and had this problem within 6 months of ownership. It was the valves that fill the ice trays not completely closing when tray is filled (continued to drip--building up an ice block on the back wall and in the ice tray. I replaced the set of valves in the lower right (when looking at the back of the fridge). Problem solved, has worked perfectly since.
May 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
292 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
