Question about Maytag Washing Machines
Maytag washer LAT9300 problem with gray chips coming out with drain water.
  • 868 Answers
That is hard water thats formed under the tub.You would have to pull out the tub for access.And then youll see the chips stuck all over the tub. Please rate this. Thanx
Posted on Jun 05, 2008
Maytag washing machine no water coming in
check water coming out of hoses. check on hot and cold fill. could be fill valve
Feb 09, 2013 | Maytag Legacy MAV208DAWW Top Load Washer
My Epic Z front load is leaking water . It looks like the gray rubber on the door is the cause. The machine is only 18 months old
In the front on the bottom of the gray seal is two drain holes, make sure there is not an obstruction in these drain holes such as a small sock .
May 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Main hose disconnected?
theres a peice of usually white pipe on the back of washer about 1 1/2.diameter. should be easy to find sounds like clamp gave way..or did it come off on the inside of washer.
Jun 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Leaking water for washer machine
Check your drain, drain hose (make sure the clamp is tight) and check the pump to make sure that all hoses are attached properly
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag Atlantis Mav8600aww
If your timer has a gray rubber ring on it, the timer is in 4 pieces. Pull the top middle part out. Then there's a white locking piece in the center. Once that's out the other 2 pieces will pull out. Note: The photo shows the top cover removed. The locking pin is the white center. RanchMom
Apr 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
