GRUNDIG Vision II LCD has sound but picture goes into color test
Once warmed up the picture disappears completely then it goes into some sort of color cycle test where the complete picture goes blue, then white, then green, then red. This pattern cycles continuously. The sound remains ok. Turning the set off then on may bring back the picture for a short while, but generally it stays in color test mode
  • 1 more comment
  • Anonymous Jun 16, 2008
    My TV screen goes white after about ten minnutes of watching.
    I have placed the remote control on Sat/Cab. which has helped but not sure if it cured because the TV did the same thing a couple of nights ago. It used to do this every time that I turned the TV on. Now it just does it when I punch a wrong button or something?
  • Anonymous Aug 01, 2008
    I have the same problem. My TV screen turns white after about 20 minutes. I have called the technical support for RCA who wanted me to ensure that my TV remote was on Cab/ Sat. I did this a couple of times and it does not fix the problem. The only thing that works is to cut off the set and wait five minutes or more. The you can watch for another 15 minutes or so.
  • thomaspapa09 Jan 27, 2009
    i have a sony bravia flatscreen i hear sound but no pic
milmar
  • 50 Answers
SOURCE: Grundig LCD TV
try to resolder the pins of the chroma IC and some possible lose connections you can see in the PCB board...
Posted on Aug 01, 2008
  • 814 Answers
SOURCE: Insignia 26" cycles colors
This is a problem with the switching circuit on the television. The color cycling is a service test pattern for checking the operation of the color circuits on the television. This could be as simple as a cold solder joint on the circuit board or crosstalk on the circuit board or wiring causing the problem. It also could be a problem with a faulty component or the switching control IC. This should be tested in a service center to isolate the problem. The service number for Insignia is 1-877-467-4289. Hope this helps you with your problem. The second problem is not the same as the vertical lines are another problem altogether . This unit need to check for faulty components at a service center. Please call the above number for technical help with you problem. Hope this helps you with your problem.
Posted on May 09, 2009
SOURCE: Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Posted on Jun 15, 2009
budmrtn
  • 11361 Answers
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Posted on Oct 24, 2009
  • 1039 Answers
SOURCE: Panasonic TH-42PX75U Blue Screen
This could be a reception problem of the cable transmission or the cable box if used. Are you using cable or SAT box. Tv goes to blue screen if signal is weak automatically.
Posted on Dec 06, 2009
How do I replace the backlight bulk in a Grundig tv
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 23, 2014 | Grundig GU19WDT 19 in. LCD TV
Grundig LCD TV
Aug 01, 2008 | Televison & Video
Picture and sound come on picture disappears
There is probably a fault in the video processor, or there is a setting for the user colour temperature that is not properly set. Call the authorized service for advice on how to proceed
Jun 11, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Lcd problem
Unplugging the television for about fifteen minutes or so, then plugging it in again.
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
My grundig lcd vision32lxw82-8510 has sound but no picture this problem is intermitant can you help? Thanks
If the screen goes completely black but still have sound then the backlight inverter board may be going out.
Oct 31, 2009 | Grundig 15 in. LCD TV/DVD Combo
Grundig Vision 26 has vertical fussy lines taking up 1/4 screen
LCD panel faulty.You can try to resolder the LVDS panel and place a cooling block on the flatpack IC.
Jul 22, 2009 | Televison & Video
Televison & Video Logo
497 people viewed this question
Top Televison & Video Experts
