Question about GE MiniCam Pro HO98756 Webcam
Problem loading i keep trying all kinds to load it in and still having problems and i have the disc, what can i do to make it work on my computer and for your info my computer is a windows vista basic?
The drivers are bunk
Posted on Jun 21, 2008
    Sergeant:
  • 458 Answers
Driver Install
Look on the Company site under drivers and downloads. You will have to put it your model first. After you find your product you will find the drivers and more.
After you download the driver you might have to put it in a folder for it to be stored in. After you put it in a folder, unzip it in that folder and it should have an .exe file. Click on this and it should do the install. If it does not do your install you can go to the Device manager and click on the device and tell it to install or upgrade the driver. Then you will need to direct it to the folder where you have the unzipped file. This should correct your problem. I am sorry that it took this long to get you an answer. I just started working on this site recently and your question just got in my cue. I have no control over how that works. You can click on my name from now on and I will do my best to answer your question within a day.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya. I did more than try; I sent you exactly to where you could get the driver and explained how to install it.
Posted on Jun 05, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you figure out the problem? If you need more help let me know.
    Give me the make and model and I will see if there are any Vista drivers. You must not have the correct driver on the disk or you need to get an updated driver.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
Dvd tray error?
It is a mechanical problem with its disc loading tray. Either a broken loading belt, or a broken gear wheel at the disc loading section can poise this kind of problem. It can be repaired; by take out the disc loading mechanism from the set. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 06, 2016 | Curtis LEDVD1975A 19 LED HDTV DVD Player...
LG RHT498H doesnt work
It sounds like a mechanical fault. If the disc inserted is do not loaded properly into its drive mechanism, this kind of symptom can occur. Contact any service technician. Sometimes, a loose belt [at its disc loading section] might be the cause. Gopakumar Gopalan Google
Mar 07, 2014 | LG RHT498H Digital Video Recorder
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Sep 11, 2009 | Audiovox D1708 Portable DVD Player
Hi, my laptop is having problems starting up it loads up the the loading screen before u put your password in and it just stops there, i've tried a toshiba reboot to out of box state and it still doesn't...
If you hav ethe Toshiba reinstall disc, check to see if it has any kind of diagnostics loaded with it. Try starting the computer, and keep tapping the F2 key, this should load the setup BIOS screen. Go to the section in setup where you can change which boots first. Set it for the CDROM to boot first. Save the settings, and restart. Once the computer loads the disc first, look for hard drive diagnostic tools. run the diagnostics to check the hardware on the computer, it should tell you what is good, and what is not. If it is the hard drive that has failed, than that is an easy fix. The only hard part is having to shell out the cash for the new drive. Hard drives on laptops are easy to get to. They are under a door on the underside of the computer. There is probably a couple screws, and the hard drive compartment will open up. Just remove the old one, and plug in the new one. Hope this helps!
Jun 04, 2009 | Toshiba Satellite A200-0ET00X Notebook
Sports disc not loading rejecting all the time
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Dec 29, 2008 | Nintendo Wii Console
Computer keeps restarting right before loading xp
Have you accessed the BIOS each time you swapped drives?
I don't know your board but you may have to let the BIOS examine your hardware and choose 'safe defaults' for you.
Also, flaky memory will cause all kinds of hangups-
Dec 06, 2008 | QDI Group QDI Advance 10B Motherboard
Wii won't load any discs
Jun 16, 2008 | Nintendo Wii Console
Disc Drive problem
ohh.. have you try any disc? theres seems a problem to your disc drive.. the lens of your disc drive are too old enough. i suggest to buy a new one. thanks
Mar 27, 2008 | Computers & Internet
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
GE MiniCam Pro HO98756 Webcam Logo
26 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
